Disposable e-cigarettes, lithium pollution and why you should be happy and exploit it
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I know, this comes in late, Big Clive did a video on them a couple years ago, but it is just last year that the disposables market has exploded here and I literally only have to walk for 5 minutes to find at least one.
    On one hand, 5 of the cheapest disposables will buy you a basic pod vape which is 100x better and the replacement pods are half the price of a disposable once you burn the heater, but on the other, they are getting better (I'm starting to see better builds, ends that don't just fall off but are actually quite stubbornly fit and 550mAh instead of 300mAh batteries on almost all of them), so everyone should be happy and snag them whenever they find them lying around.
    I have found at least two between Christmas and New Year's where I literally used them over 12 hours outside in the cold, with real smoke, drink and sleep breaks of course, but still, that means they were basically new. But most I've found could be used at least 1 hour more indoors after the battery warmed up and recovered some charge. I have blown a few of them from forgetting the little ones on charge with straight USB, this problem was solved since they switched to the 550mAh batteries.
    I use a thinner cable now and still can't be arsed to even stick a TL431 or 1117 in line to drop the voltage, I don't even damage them anymore like this, let alone have them catch fire - and also, four little 550mAh cells in parallel make a healthy 2000mAh cell - you catchin' my drift? Free cells for reconditioning laptop batteries, especially since they have switched to the flat style now. They don't fit your wannabe Macbook? No probs - make an external power bank, since USB-C with power is on basically everything now.
    A working TV? How boring!
    • 30977
    Re: Disposable e-cigarettes, lithium pollution and why you should be happy and exploi
    use a lithium charger like a TP4056 module
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8695
      I have yet to find any to harvest
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        I use what I have around. I have over 50 TL431s and 1117s - I don't give a single crap about that. It's not fitted inside a complete PS board? Forget it.
        I also have two TI Launchpad boards and a few MSP430s. Used to be a PIC guy but I forgot where I put the programmer for those. I can code my own charger. Can't be bothered to.
        There is too much other stuff around for me to fix from what I have already picked up or gathered in 15 years - and every day I find more.
        • nerdmafia
          • Mar 2023
          • 9
          They have really taken over here in the USA as well. Only hardcore vapers like me still have actual tanks or subohm devices, and blow clouds for that matter.
          My girlfriend has been buying a new disposable every few days for $20 to $30. No, she won't listen to reason.
          I use a lab DC power supply to determine how dead or full the battery is based on how much current it draws. Those that have USB-C or MicroUSB charging ports.
          Next, I restore them entirely by simply squeezing (homemade) nicotine juice right into the mouthpiece, shake, wait, shake, and this can be done several times until eventually the oxidation layers on the coil foul the taste.
          So you use thin wire so as to function as a fuse?
          When taking the apart, there are definitely 1 or a few ICs in there doing something.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8695
            Still haven't found any!
            Where's my free Li-ion batteries! Need more to replace batteries in my Garmin!
            • harp
              • Jun 2022
              • 598
              • Planet Earth
              look around the places where there is the biggest infestation of tourists
              • RethoricalCheese
                • Mar 2013
                • 1517
                • Estonia
                Not sure about the great muricaah but in EU, you can just return such ewaste (lightbulbs, batteries, e-cigs and much more) to stores for free. So many places have buckets full of these things. So I just asked for hundred or so.
                  ASUS ROG G512LI-HAPPY Notebook Strix G15 Specification for Upgrade or Repair
                  This specification for the ASUS ROG G512LI-HAPPY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G512LI-HAPPY boardview and G512LI-HAPPY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-06-2024, 11:40 PM
                • cheeky2
                  Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                  by cheeky2
                  For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                  See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                  01-08-2024, 05:56 AM
                  Windows Print Spooler RCE exploit: "PrintNightmare" (old title: ffs)
                  by stj
                  just how many backdoors do these fuckers have that are currently undiscovered???
                  https://www.theregister.com/2021/07/...tmare_patched/
                  as an ex programmer,
                  i'll say right now that you are NOT looking at a fucking bug.
                  the way software handles "data" is totally different to extended code routines. (library's, dll's etc)
                  to say windows is not completely compromised by design is a total joke at this point.
                  07-07-2021, 11:01 AM
                • Cory Meyers
                  🤯 Acer Predator Helios 300 pH315-54
                  by Cory Meyers
                  Hi there all, 1st post here. I wasn't aware there were guys out there doing this for people! (how, well I haven't a clue lol but 😎👍 badass!), So when I found y'all, I was happy, but not too happy quite yet - although my issue seems to be less severe than many I've seen here who have been happily helped, so there's that.
                  I'm a software dev of over 20 years and just recently have gotten into the hardware side of things plus other electronics like Rpi and Arduino. Started off a vid game hacker yada yada, same story. Lol.
                  Now, the BIG OL' issue ruining me little life:...
                  10-28-2024, 05:11 PM
                • Topcat
                  Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
                  by Topcat
                  Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
                  Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
                  09-29-2024, 03:55 PM
