I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or if your router loose power and reboot it can not reconnect on it own
So the solution for this issue is to put a battery backup on both the router and the garage door opener but this part is weird also because the garage door opener has a battery so you can open the door
Which opens up with the wall switch button so I do not understand the logic behind that I guess I need to call tech support again and see if they know what the issue with this is
Now the garage door application is very good when it works and has good WiFi signal but I wonder if they track when your door is open and closed and when huh
