Can anyone find this DC jack online?
  • survivalbloke
    • Aug 2021
    • 309
    This is off a Dell Inspiron AIO, motherboard# IPTGL-CL Rev A00. I don't have the service tag to this machine as it was missing. https://i.imgur.com/FXY7LCh.png
    Followup question: How do people figure out part numbers to ports and such? If I type in the markings of a USB c port into google I usually get nothing. However if I search for "Lenovo X280 USB c port", I get listings for the port. How can I identify these in the future?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Can anyone find this DC jack online?
    Any chance of the important bit being in focus ?
    Click "Go Advanced" below and then the paperclip to attach images direct.
    Part numbers ? I use visual inspection/comparison and Aliexpress.
    • survivalbloke
      • Aug 2021
      • 309
      Here it is! Thanks for the reply!
      • diif
        • Feb 2014
        • 6978
        • England
        I think this is the one. https://www.aliexpress.com/item/1005001350451149.html
        • survivalbloke
          • Aug 2021
          • 309
          Killer! Too bad those markings on it don't mean anything much. I guess those are just production numbers or something. Thanks!
            • 22030
            This one https://www.ebay.com/itm/234383261991
            • survivalbloke
              • Aug 2021
              • 309
              Damn! Just ordered one last night from California(and I'm in Maryland). lol. Thanks!
              • anachronon
                Need to Find Replacement Audio Jack for Vizio TV
                by anachronon
                I have an older Vizio M3D460SR TV, and the audio output jack has started to malfunction. The jack output is connected to my stereo. The other day, I had to disconnect the audio cable from the jack, to reach behind the TV. The problem started after I reconnected the cable. Now, the audio began randomly switching from my stereo, to the TV speakers, and back again.
                My initial suspicion was a bad solder connection. So, I opened-up the TV, pulled the main board, cleaned all of the old solder off of the jack terminals, and resoldered them. But, the intermittent problem has persisted....
                05-17-2020, 05:17 PM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • YOUCEF4787
                Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                by YOUCEF4787
                I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                Initial Problem:
                The laptop was completely dead, no signs of life, no power LED.
                Action Taken:
                I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                Current Situation & The Main Issue:
                The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                09-21-2025, 12:19 PM
              • danielgerman681
                ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                by danielgerman681
                Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                08-27-2025, 01:17 PM
              • Geeker007
                9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                by Geeker007
                Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                I am new to electronics repair, so my queries could be naive but I am ready to learn.
                So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                01-28-2025, 03:31 PM
