Can anyone find this DC jack online?
  • survivalbloke
    • Aug 2021
    • 293
    This is off a Dell Inspiron AIO, motherboard# IPTGL-CL Rev A00. I don't have the service tag to this machine as it was missing. https://i.imgur.com/FXY7LCh.png
    Followup question: How do people figure out part numbers to ports and such? If I type in the markings of a USB c port into google I usually get nothing. However if I search for "Lenovo X280 USB c port", I get listings for the port. How can I identify these in the future?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Can anyone find this DC jack online?
    Any chance of the important bit being in focus ?
    Click "Go Advanced" below and then the paperclip to attach images direct.
    Part numbers ? I use visual inspection/comparison and Aliexpress.
    • survivalbloke
      • Aug 2021
      • 293
      Here it is! Thanks for the reply!
      • diif
        • Feb 2014
        • 6978
        • England
        I think this is the one. https://www.aliexpress.com/item/1005001350451149.html
        • survivalbloke
          • Aug 2021
          • 293
          Killer! Too bad those markings on it don't mean anything much. I guess those are just production numbers or something. Thanks!
            • 20842
            This one https://www.ebay.com/itm/234383261991
            • survivalbloke
              • Aug 2021
              • 293
              Damn! Just ordered one last night from California(and I'm in Maryland). lol. Thanks!
              • anachronon
                Need to Find Replacement Audio Jack for Vizio TV
                by anachronon
                I have an older Vizio M3D460SR TV, and the audio output jack has started to malfunction. The jack output is connected to my stereo. The other day, I had to disconnect the audio cable from the jack, to reach behind the TV. The problem started after I reconnected the cable. Now, the audio began randomly switching from my stereo, to the TV speakers, and back again.
                My initial suspicion was a bad solder connection. So, I opened-up the TV, pulled the main board, cleaned all of the old solder off of the jack terminals, and resoldered them. But, the intermittent problem has persisted....
                05-17-2020, 05:17 PM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • Geeker007
                9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                by Geeker007
                Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                I am new to electronics repair, so my queries could be naive but I am ready to learn.
                So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                01-28-2025, 03:31 PM
              • corrize
                Where to find a very small fpc connector 0.3mm between 2 pins ?
                by corrize
                Hello, I search this connector (oxydated).
                It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                Do you know how to find this connector please ? What is the exact name for find it ?
                08-06-2024, 05:25 PM
                Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                by sam_sam_sam
                This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                07-07-2024, 02:34 PM
