Is it possible bridging tiny broken trace
Re: Is it possible bridging tiny broken trace
It can be done (about 0.1mm line with 0.1mm gap) on the condition that attention is paid to the sequence of procedures.
This video is repair of flex cable but the principes is the same with one on PCB board.
https://www.youtube.com/watch?v=PO6b5VD7bbg
Precise repair of damaged lines on flat flex ribbon cableLeave a comment:
You have a multiple broken track on near field. If you are not making it worse till now, you may try to follow each side of track and solder fine regular jumper wire on legs of ending components. I see a lot of vias, so it is posible that this track go around the board.
https://m.youtube.com/watch?v=F_Mi-SwZyxY
Yes this will be look messy but you can skip micro work on micro space, and macro trouble.
For coating and fixing small area use hard rossin dilueted on ipa and few drop of glicerin, this is sticky but when ipa disapeer, it solid and firm. On jumper wire apply drop of hot glue every inch...Last edited by harp; 12-16-2022, 09:39 AM.Leave a comment:
you should do the cleaning back by hand or the heat and the revolving motion will lift the copper and cause more problems .. follow the traces back and place jumpers if possible then deal with what's left . and going to different places on adjacent tracks minimising short circuit issues . this is my hindsight after making it very hard work for myself ..good luck and hope you sort it .. oh and magnification and clear view is what's needed here . tin the wire and the track first .Leave a comment:
Or use scotch brite pad on a dermal tool at low speed should work but do over due the amount of pressure that you apply to the disk for best results
You can also use wire strains that are very fine I done before but I caution you to take your time doing this it is very difficult and time consuming to do this just be patient doing this project for best results
Being that the traces are so very close to each other this is going to be very difficult to doLast edited by sam_sam_sam; 12-09-2022, 08:18 PM.Leave a comment:
i wouldnt, that will go through copper so fast!!!!
a fibreglass brush would be betterLeave a comment:
Yeah, the only thing this tool is good for is to clean up the damaged area. Well you can try it out on the already damaged spot and practice.Leave a comment:
That's not the tool I would use but if you think you can remove the mask and leave the copper underneath then go for it. Some wet and dry sand paper would be a bit more delicate.Leave a comment:
and I have grinder which I purchased a few month ago.
Although Its size is very big comparing with the size of broken trace, It can be control rotating speed from the slowest to the fastest.
https://www.aliexpress.com/item/1005003683079012.html
The tip you have is fine. Your priority is to grind away the solder mask, then tin the traces then bridge the gap. UV mask is after the work is done and tested.Leave a comment:
Thank you very much for all of reply.
It seems that 0.15mm soldering tip(T12 ILS) is the most finest tip I have.
So I think to purchase fine tip is the priority than to purchase UV solder mask.
I browse through aliexpress and found below link of 0.1mm soldering tip.
https://www.aliexpress.com/item/1005002701753416.html
Is it possible to use this 900M-T-BI tip for any T12 compatible soldering station?Leave a comment:
you can get UV flashlights on aliexpress for as little as $3
they use an 18650 and are very handyLeave a comment:
also acrylic conformal coating (MG chemicals) will work. Stinks bad like nail polish and you gotta wait for it to dry. The other UV solder mask doesn't stink and it's much faster. Yes you need some sort of a UV light, there is really not getting around any of that.Leave a comment:
You could use a dab of nail polish.Leave a comment:
I'd be putting something like this : https://www.aliexpress.com/item/1005...d=cymzUU5M2RcF
on these little wires, so they stay put after you finished the re wiring job. The last thing you want is one of the little wires to fall off for some reason. This UV mask is like liquid, until you hit it with a UV lamp. Once you hit it with a UV lamp it becomes solid and glues the little wires in place and protects them. Up to you to use it or not. If something goes over my desk with a small trace repair, I use some sort of UV curing mask to keep the little wires in place. Also you wouldn't want all these little wires to short out against each other, if the wires are bare copper.
It seems that UV curing solder mask has significant benefit if wire is bare copper or I want to clamp wire on PCB.
But I don't have any UV lamp, Is it possible to make UV curing solder mask soild with staying in the sunshine for an hour?Leave a comment:
on these little wires, so they stay put after you finished the re wiring job. The last thing you want is one of the little wires to fall off for some reason. This UV mask is like liquid, until you hit it with a UV lamp. Once you hit it with a UV lamp it becomes solid and glues the little wires in place and protects them. Up to you to use it or not. If something goes over my desk with a small trace repair, I use some sort of UV curing mask to keep the little wires in place. Also you wouldn't want all these little wires to short out against each other, if the wires are bare copper.Leave a comment:
Currently I don't have any UV curing solder mask.
If I try microsoldering like bridging tiny broken trace without UV curing solder mask, would it be serious problem?Last edited by chth96; 12-04-2022, 10:15 PM.Leave a comment:
After the wiring job I’d put UV curing solder mask on it. But heck… that’s a bummer. Not impossible, but I suggest you get a fine tip for the soldering iron.Leave a comment:
some people use this flux from ali express and get good results using it https://www.aliexpress.com/item/3228...d=aeMiejKG9aPvLeave a comment:
That's quite a few traces there.
You'll need to remove the solder mask in that area so you have clean copper to solder to and to get a better look at the damage. There are cheap grinding pens available, they are better than scraping at the board with something sharp. https://www.aliexpress.com/item/1005004662172521.html
You want to flux the area then tin the traces with solder, then use either fine wire or the PCB trace repair kits. https://www.aliexpress.com/item/1005003152519345.html
Then solder mask on top when you know it's good.
Is it good enough to purchase any flux from aliexpress?
https://www.aliexpress.com/item/1005004658782043.html
I only has tweezer and small size screw driver for picking up or cutting wire
And broken trace seems too small by comparison with size of both tweezer and screw driver currently I have ..
Is there any toolkits for picking up or cutting 0.1mm diameter wire?Last edited by chth96; 12-04-2022, 06:22 AM.Leave a comment:
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by chth96I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine
Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
Is there any way to remove flux with the smallest rubbing or without any rubbing?
Any reply would be appreciated. -
by mrfomtHello.
Have a HP Elitebook 840 G2, should swap the bios so I desoldered the main bios chip U365. The solder pad on pin 5 broke. si/sio0. Can't find the chip in the schematics. Maybe I could solder a wire from pin 5, but don't know where the other end of the wire should go. -
This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-12-2024, 03:36 PM
- Loading...
