Rework with Scotle IR-PRO-SC
  • N3Star
    • May 2021
    • 40
    I'm having major trouble with rework on this station. I (since most likely it's profile problem) keep killing or at least damaging chips. For now I'm using 3 TCs, 2x0.127 and one 0.25, all omegas, all are within 3 degrees from each other, I try to keep the TC end on the substrate and motherboard. GPU usually moves at ~225-230C on TC, so it's more less accurate. I mainly rework old GPUs and Xbox 360 on it. I have modded it to use variable bottom temp with P-soft, bottom max temp is 260C, realistically on thinner PCB I get 200 degrees, ramp is +60C from the profile (set like that so that top heater keeps up on 5-20% power up to ~180C). Top heater is about 4cm above flip chip. My profile is:
    r1:0.38 L1:130 d:1 ---> on this step it ramps very slowly up to ~ 150C and then goes to:
    r2:0.5 L2:220 d:200 ---> I never need to go higher or longer than that
    Whole process takes ~ 9-10min, which is long, but profile I made from an extended SAC305 reflow profile killed every chip I tried.
    (5mins till GPU comes off, but back then I tried to keep the GPU at 220-221C max;
    r1:0.78 L1:100 d1:20 ---> ramps up to 150, slowly goes to 180, then:
    r2:0.8 L2:220 d1:200)
    On this at least I don't see solder balls coming from under the flip chip, though reflow usually leads to artifacts or black screen, so no short, but also not working. If it matters flux I'm using is either Amtech NC-218 or NC-559.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Rework with Scotle IR-PRO-SC
    Your top heater max temp looks low 200c max ?
    Bottom heat lower, top heat higher.
    • N3Star
      • May 2021
      • 40
      No, 200C was test only, I wanted to see what temp I would get without top heater (real bottom temperature). As I said on a regular profile I can take off the chip at ~225-230C.
      • diif
        • Feb 2014
        • 6978
        • England
        You have your bottom at 260c and your top at ?
        • N3Star
          • May 2021
          • 40
          All my profiles go up to 220C, but due to thermal inertia it's higher, I never saw any temp higher than 230 on TC though.
          • diif
            • Feb 2014
            • 6978
            • England
            I have 200 on my bottom and I think 230 on the top.
            • N3Star
              • May 2021
              • 40
              OK, how does Your profile look? I mean the slope, I think as long as it's made for IR upper heater I'll be able to replicate and try it. I also drew a rough sketch of how my profile looks like.
              • diif
                • Feb 2014
                • 6978
                • England
                I can't give you the exact settings at the moment but my top heater profile looks like a standard reflow profile. https://duckduckgo.com/?q=reflow+pro...e_17451(2).jpg
                My bottom heater heats the whole board to around 100c and the top heater does most of the work. I have my heater closer. It's an Elstein element.
                • N3Star
                  • May 2021
                  • 40
                  OK, if You do anything later then please do take a picture of the slope. I'll also try on my own to more or less replicate that profile.
                  BTW, while we're at it, do Your boards get yellowed? Mine after 5min profile are in immaculate condition, but those after 10min one are kinda yellowed.
                  • N3Star
                    • May 2021
                    • 40
                    Earlier today I did a test of how quickly this machine (100% power bottom heater only) can get a Xbox 360 mobo up to 200C, results in picture. I tried to make a profile out of it, it's about 300 seconds long (not included bottom heater initial phase of getting these +60 degrees), suitable for 70-90% power of bottom heater, I also upped the top heater temperature to 225C.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      I don't really have a slope, more a shape I showed earlier.
                      It rises at a couple of different rates and holds then rises to finish for the last bit before turning off, then I engage the fans.
                      It was a while since it was set up and I have no idea where the laptop is that we used to set the profile.
                      • N3Star
                        • May 2021
                        • 40
                        For *some* reason I just cannot solder with rss profile, it has to be more of rts shape. Though I like leaving a bit of time for the PCB at 130-170C to soak this temperature.
                        Don't sweat it, but do You remember temperature rise rate for the final step? Since You have IR plates at 120C it's likely that our stations differ quite a bit, because mine doesn't have bottom HR component, it's all dark IR. This also seem to differ with other knowledge I got (bottom should do most of the work, top only for the last step), but then again everybodys profiles are like 5-6 minutes and mine is almost 9min long.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          I soak at about 200/210 before the final push, I think we have near identical stations. Apart from my upgraded top heater.
                          I will be able to get more precise details of the profile in a few days.
                          • edugimeno
                            Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                            by edugimeno
                            Hi!!
                            Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                            I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                            At a certain point, moving stuff around, I put all wires back in place and...
                            03-24-2024, 02:31 PM
                          • madan1
                            Diesel heater emergency power supply / poor man's UPS
                            by madan1
                            Hello everyone.
                            Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                            12-18-2022, 08:05 PM
                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                            by sam_sam_sam
                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                            12-16-2023, 08:39 PM
                          • petemanuk
                            Help with IR6500 rework station
                            by petemanuk
                            I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                            1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                            2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                            10-14-2022, 12:31 AM
                            Multifix 425-01 and 450-01 Rework Flux Datasheet
                            REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                            - No Clean Formulations
                            - Low residue
                            - Range of activity to deal with different component solderability
                            - Halide free
                            - Suitable for dispensing
                            - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                            Both products are supplied in syringes or cartridges for application by dispensing....
                            10-07-2024, 06:02 AM
