B&K 467 CRT Tester
  • japlytic
    • Oct 2005
    • 2086
    B&K 467 CRT Tester
    On eBay, I bought a B&K 467 CRT Tester at a low price. Before I made a bid, I did some research on this model and found an extensive list of CRTs which can be tested with this unit .
    Included with the unit were the instruction manuals and a circuit diagram with timing waveforms, as well as CRT adaptors for TV sets intended for sale in Australia around the time colour TV was introduced.
    Upon inspection after arrival, it needed some work.
    Several resistors were out of tolerance, even though they were 5% units, which included R36, R69, R40, R41, R46-R48, R31, R70, R58, R38, R37 and a 1M0 unit on a rotary switch.
    D36 and D37 (each 56V) were internally shorted, and were replaced with seven 16V Zener diodes to get the original voltage of 112V, and seven units would be able to dissipate more heat.
    There were minor differences in my unit, which included Q1-4 being 2N5551 units, as well as Q5-7 being better-rated BF337 units. Also, the resistors in parallel with most of the neon indicators were 11M units.
    The G1 voltage indicator activated under "SET-UP" mode is somewhat inaccurate, even though R19 was OK, and even replacing meter sample and hold capacitors C1-C3 did not help .
    When testing out, I got no Screen (G2) voltage at the output connector; this was caused by a wire pinched between a control and the chassis, causing the wire to become bare and touch the chassis (R43 got hot and made a bit of a smell) . Fortunately, no damage occured .
    Later, I had problems with the Red section of the circuit. Replacing Q1 to Q4 as well as D21 to D23 (and checking pots R49 to R51) did not help , so I decided to compare waveforms of TP1, A, B and C (normal and inverted).
    Waveforms B and C (both either normal or inverted) did not check out, so attention was focused on the 7400 chip.
    When this chip was about to be removed, a pin was found to be bent and was not in its socket.
    Reseating this chip fixed the problem with the Red section .
    The solder joints on the rotary switch were also reworked.
    Finally, the Heater Voltage indicator was calibrated, as well as the Line Voltage indicator being calibrated with an on-line pure sinewave UPS which had its output measured.
    Interestingly, the two patents pertaining to the TriDynamic feature were consecutively numbered (3,961,241 and 3,961,242 (not 3,962,242). This feature made this equipment quick to learn how to use.
    C1-C3 across the meters were quite large to hold the pointers steady as possible as the TriDynamic logic switches each colour section.
    The one and only valve/tube (a current-production 12BH7A) is used for the Screen (G2) voltage regulator, since there were not enough transistors which can tolerate high voltages (630V) reliably.
    I needed a universal CRT adaptor, and I initially considered cutting the leads off a supplied adaptor, but I did not to do this because the tester was supplied with a homemade CR/CA 6 (B&W) plug to CR/CA 7 socket, which the CR/CA 6 plug fitted the CR/CA 5 (colour) adaptor.
    The CR/CA 5 adaptor had all of the CRT signals (there was a common G1 and G2 at the tester and adaptor), so the homemade adaptor plug had an extra pin (stiff wire) added to make use of all CRT signals, with lengths of coloured wire corresponding to the circuit diagram connected to the plug, also with IC test clips on the other end.
    This homemade universal adaptor is used with the CR/CA 5 adaptor.
  • mockingbird
    • Dec 2008
    • 5484
    Re: B&K 467 CRT Tester
    I wish I knew half the things you were talking about, but good work!
      • 31198
      you need to make an adapter for narrow neck tubes,
      then you can blast all those damned widescreen tubes with gun-shorts!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i use a gutted color brightener and a socket robbed from a junk set.
        plugs into #3.cheap and easy.parts are free.resolder that row of connector pins along the edge.#1 problem.#2 is someone trying to test a crt with the chassis running.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          i do the same with a brightener.take out the transformer.pry open the female end and straighten the recepticals.cover them in heatshrink.one free universal adaptor!
            HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
            09-06-2024, 08:50 AM
          • Lifeisfun
            Trying to troubleshoot DDR4 SODIMM slot with slot tester
            by Lifeisfun
            Hi folks!
            I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
            Eventually I discovered that it was related to moving the laptop.
            Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
            If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
            I removed the board got one of those memory slot testers...
            06-04-2025, 02:26 PM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
            FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
            by sam_sam_sam
            https://www.ebay.com/itm/405035016711
            I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
            I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
            04-13-2025, 08:17 PM
          • Simonc123
            CH341A bios chip wont fit 1.8v adaptor holder
            by Simonc123
            Hi guys, I need a bit of help. I use a CH341A programmer, which is fine for 3.3v old-style bios chips. I need to reprogram some 1.8v chips, which are QFN type chips. I have the 1.8v adaptor for that slots onto the programmer, which does step the voltage down to 1.8v, but as you can see in the picture added, it doesn't fit in the IC holder.
            Please see the 4th picture that shows what looks like what should work for the QFN IC (highlighted in red). The issue is that the 8 pads on the programmer are too long and short out the IC. Is it a case of putting kapton tape over the center ground...
            03-09-2025, 08:54 AM
