Busted AGP slot.
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Busted AGP slot.
    I have a mobo here with a fast AMD cpu on it. My brother somewhat busted the AGP header.He tried to pull the video card out of it with out releasing the clip. To me it looks like busted/cold solder joints are the problem now. It will pick up the video card if you play around with how its inserted. All the contacts in the header look good and tight. What is the watt, name and size of the soldering iron tip I should use to try and touch up these fine solder joints? I could get around this by using and old regular PCI video card but where would I find one that is big and fast enough to run under windows Xp?
    Mark Twain
    John Paul Jones
    Rod Serling
    • 31011
    Re: Busted AGP slot.
    a 1mm spike tip is probably best.
    and .5 or .7mm solder
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Dang...I just took that board out in the sun for a good look and I found a burnt off trace in the AGP slot area on the back side. The magic smoke has been let out of it. I did find a Matrox regular PCI video card in my junk pile. I'll try it with that. This is one of those rare times when I wished a mobo did have onboard video...This stupid board is a K7S5A.
      Mark Twain
      John Paul Jones
      Rod Serling
        • 31011
        jumpwire the trace.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Originally posted by Junk Parts
          Dang...I just took that board out in the sun for a good look and I found a burnt off trace in the AGP slot area on the back side. The magic smoke has been let out of it. This stupid board is a K7S5A.
          oh well.. not really a loss.. (unless it was completely recapped earlier)
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Well its up and running with a Matrox Graphics Mystique PCI video card. I'm using it for this post. Its not bad. I think this is my old card I used back in my AMD K6/2 days. As far as the burnt trace goes, my soldering skills are not up to the task. All I can come up with is using a strand or two of thin wire to jump the burnt spot. I may get brave and try it one day.
            Mark Twain
            John Paul Jones
            Rod Serling
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              get brave and try it. you can do it.
              sigpic
              (Insert witty quote here)
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                Well I reset the primary display mode to AGP 4X this time and stuck a 64 meg ATI rage card in it and it picked it up right up. Been working fine ever since. I also had to sort out an issue with a bad stick of ram. Replacing the failing stick made things work much better. I was thinking that it was the DVD drive acting up. I changed it out for the new one from my Dell and it still acted up by giving me BSD's. I knew I had a gig of ram in it but it was only showing 512. These were two matched sticks of Kingston. I switched in a gig of crucial and it now shows all the ram and works fine. This four new matching sticks of 512 kingston I have came from a little junked compaq that was given to me to part out. It never saw its ram right and BSD'd alot. Now I know why... This also means a good little PC went to the bin because of one bad stick of ram!
                Mark Twain
                John Paul Jones
                Rod Serling
                  • 31011
                  kingston may have lifetime warranty - check it out.
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    Yes I would like to replace it as the kingstons are now my test sticks because the crucial is in the K7S5A mobo. Then again one stick of kinston 512 DDR can't cost all that much. Because I have the same kinston ram in the dell I just may switch it for the crucial from the K7S5A then use this kinston as test ram. I don't need the K7S5A for anything right now. After I look into a cpu upgrade to make SSE happen with the K7S5A it will leave my hands anyway. Its just may be the "new" PC for my "PC Killer" sister inlaw...LOL I do have some junk "no name" 512 sticks that just may kick it. There is also two sticks of crucial 256 DDR ram around here someplace. This would work if I ever find it...LOL
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      Here are a few specs from the mobo book just to make sure about this upgrade.
                      Socket A Processor "other places in the book it says socket 462"
                      Supports AMD Athlon/Duron
                      Supports 200/266 MHz FSB
                      "I have 1Gig of DDR 266 in it right now"
                      Processors are automatically configured using firmware and a synchronous Host/DRAM Clock Scheme.
                      The board is a K7S5A v1.0
                      The book also says: The following processors are currently supported
                      Athlon 650 MHz~1.4 GHz, FSB: 200 MHz, 266 MHz
                      Duron 550~950 MHz, FSB 200 MHz
                      I'm just trying to make sure of things here. I don't want to let the magic smoke out of the thing just yet...LOL
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        I just took the CPU out. Why in the hell do people think it takes a whole tube of heat sink compound to do one cpu! The whole top of the cpu was covered in cheap white compound! I have never found this much heat grease on one cpu in my life. My brother must have gotten this thing as a CPU, mobo bundle because he knows how to use this compound right. Anyway here is what it says on the chip.
                        A1000AMT3C
                        As I found on the net, this should be a Tbird C.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          http://www.cpu-world.com/cgi-bin/Ide...T3C&PROCESS=Go
                          http://www.cpu-world.com/CPUs/K7/AMD...1000AMT3C.html
                          K7S5A's also take Athlon XP's up to XP2600+ with Thoroughbred core or up to XP2000+ with Palomino core
                          (use cpu-world.com to identify those or get the AXDA_____ part numbers if you want to upgrade)
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            Thanks. I found a new junk pc shop to deal with now. I'll be looking for the right xp 2600+ but I'll also go for what ever Xp xxxx+ cpu that has SSE in it If I can't find the good one at a good price. I was just on that site you posted. Good site!
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              go there
                              http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
                              and in the gray box above where all CPUs are listed, select "FSB 266MHz" and either "Core Thoroughbred" or "Core Palomino".
                              that way the site only lists those CPUs (which are the ones compatible with that board) so you can get the AXDA_____ part numbers to search on ebay (or whereever) for
                              - selecting both Palomino and Thoroughbred gives no results (no CPU with both cores at once :P)
                              - if you click on a cpu link after filtering, and go back in your browser, the filters are reset. -> open links in new windows/tabs
                              or just let me dig through ebay.com and find the cheapest compatible one so you dont have to search..
                              which would be this one
                              http://cgi.ebay.com/200255782714
                              lets just hope you don't read this after 30mins of digging through cpu-world
                              • pfrcom
                                Oldbie
                                • Jun 2006
                                • 1230
                                Caution Junk Parts
                                I think you said previously that it's a K7S5A v1.0
                                I don't think a version one will have processor support equivalent to the later versions
                                better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2642
                                  V1.0 - 3.1 all support the same CPUs.. up to XP2600+ Thoroughbred.
                                  the only thing you need to make sure it to have the latest BIOS on it.
                                    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                    09-12-2024, 02:00 PM
                                  • totoagung2
                                    by totoagung2
                                    Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
                                    Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
                                    01-01-2024, 02:43 PM
                                    GeForce RTX2080 Super Aero video gaming card issues help need
                                    This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                    Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                    05-07-2023, 08:12 AM
                                    HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                                    09-06-2024, 06:20 AM
                                  • abajor
                                    x1 Carbon Gen 9 HYG60\HX4B0 NM-D341 Rev: 1.0, CSD87501L Failed solder Joints.
                                    by abajor
                                    I had a x1 Carbon Gen 9 come in with a no charge and no USB C power up problem (the machine would turn on with a new battery until it lost charge).
                                    I noticed lifting the protective black membrane near the USB jacks that two little BGA chips were stuck to the adhesive and had fully released from the mother board, one of them looking fully scorched. Q261 and Q263 power MOSFETS.
                                    I found the schematic and diagram for the board here.
                                    https://www.badcaps.net/forum/troubl...e-devices/sche...
                                    07-20-2024, 04:46 PM
