Alternative to RatShack soldering bulb?
  • 4tified
    • Jun 2008
    • 55
    I couldn't find anything on this, so...
    I have been recapping motherboards for a few years, and have a decent Weller soldering station (WLC100) that I like alot. Easy to use and maintain. However, I am in need of a good desolder device since 98% or what I do is rework.
    Radio Shack bulbs suck. They only last a week and do more damage than good. I at one time had a Hakko 808, but had to return it the next day due to needing money for unforeseen circumstances. I never got a chance to learn to use it.
    Is there a cheaper alternative to the Hakko 808? I 'd prefer something that didn't need braid, as most of the work I do is through-hole, not surface mounted.
    Thanks!
  • delaware74b
    • Apr 2009
    • 628
    Re: Alternative to RatShack soldering bulb?
    I use the vacuum desoldering tool that ratshack sells for $10. It does a decent job on older single-layer boards that don't have that d***ed lead-free solder. If i'm working with lead-free, I add a little 60/40 solder to the joint and desolder it. I'm using the Weller WTCPT soldering station with the standard PTA7 (700 degrees).
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • 4tified
      • Jun 2008
      • 55
      The problem with the RatShack desolderer is that I have gone through at least 15 of them in the past 2 years. It works great for the first 2 boards, then quickly starts to lose heat intensity with every use. I have cleaned and replaced tips like yesterday's news. What eventually ends up happening is that there is not enough heat to melt the solder, OR the tip begins to dig around the PCB, eventually damaging the tracks and leaving no place for the solder to bond.
      I know this is a noobish question and I'm sure lots of people are probably skipping over this post without giving it a second thought, but this is my second income, so I have to figure out a better solution. If anyone else has any suggestions, I am all ears.
      • larrymoencurly
        • Oct 2004
        • 960
        Drilling out the hole of the Radio Shack solder sucker helps, but generally I haven't had very good luck with the thing. I've done better with a soldapult, and attaching a short length of silicone rubber tubing to its tip should prevent board damage when the soldapult is triggered.
        As I mentioned in another thread, the Radio Shack desoldering iron works better if the voltage is increased slightly (emphasis on "slightly"), and people have made modifications like insulate the cylinder above the tip, cut the tube to the suction bulb, near the cylinder, and inserted a length of silicone tubing as a thermal break, replace the suction bulb with a soldapult, electric vacuum pump, or foot-operated tire pump modified to suck instead of blow.
        The only cheaper alternatives I've seen to the Hakko 808 are a Chinese knock-off on Ebay for about $120, delivered (uses 240VAC), and some of the Blackjack brand equipment from Circuit Specialists.
        • yyonline
          • Jul 2009
          • 692
          I don't know about alternatives, but I can vouch for the Hakko 808 being a very nice tool. I can remove all the capacitors (or whatever else) from a board in a matter of minutes. It's not the cheapest tool, but it easily paid for itself after a few repairs just in time savings. Only complaints I have about it is that it can get a bit heavy after prolonged use (minor issue, really, it's not that often i use the thing for more than a few minutes). Also, it requires cleaning fairly frequently as the solder collector fills up after awhile and blocks airflow to the pump.
          • severach
            • Aug 2007
            • 1055
            The Hakko 808 is about $165. I've heard of Knockoffs as low as $100. Not enough of a price difference to go cheap. The $53 per Hakko tip tends to make my eyes wander elsewhere. The Hakko tips are good. I have yet to wear out my first one.
            When paired up with a regulated SMD hot air gun the Hakko snorts lead free solder very fast with much less contact time and board damage. It's great for clearing stubborn holes.
            sig files are for morons
            • yyonline
              • Jul 2009
              • 692
              They are decent tips, but I just paid $14 for a replacement. If you're paying $53, might want to look elsewhere. Unless we're talking about a different part...
              • 4tified
                • Jun 2008
                • 55
                I went back to Fry's and reluctantly purchased the Hakko 808 again, now that I have a little extra money to play around with, I can keep it.
                Oh my God. Now I know what all the fuss is about. I have NEVER had a tool that removed solder from every single through-hole capacitor I've replaced. Usually I end up almost damaging the tracks or having to remove excess solder with a steel needle. Thanks for pushing me towards the Hakko, it has already paid for itself twice over!
                Board rework is actually fun again!
                • Norrecito
                  iPod nano G3 - alternative soldering point for the white battery wire
                  by Norrecito
                  A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
                  The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
                  This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
                  09-07-2024, 03:54 AM
                • repair-it
                  TOSHIBA DLP 52HM95 How to reset timer module on bulb
                  by repair-it
                  I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                  Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                  10-11-2023, 07:18 PM
                • Azurain
                  Elitebook 840 G5 Bios Chip Soldering Question
                  by Azurain
                  I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                  Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                  04-14-2023, 06:58 PM
                • ezenia
                  LUMIMAN Smart Bulb IC ID?
                  by ezenia
                  I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                  In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                  04-28-2025, 05:56 PM
                • JimBanville
                  Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                  by JimBanville
                  I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                  Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                  01-24-2023, 07:49 AM
