New Cheap Chinese Soldering Plates
    • 31294
    Re: New Cheap Chinese Soldering Plates
    Originally posted by clearchris
    Thanks for the idea. Kapton tape should probably work in this instance, there's little risk of the tape falling off and burning up since it's already temperature limited.
    you could put a strip of spring-metal on one corner mounting hole to press the thermocouple to the plate
    • diif
      • Feb 2014
      • 6978
      • England
      Just jam the thermocouple in the end between kapton tape and profile.
        • 31294
        but thats reading the ptc and not the aluminium
        • diif
          • Feb 2014
          • 6978
          • England
          As they are all touching the ptc should be the same as the aluminium.
          The flat parts are also colder than the middle, so upside down the flat surface has an uneven heat anyway.
          • clearchris
            • Dec 2013
            • 687
            Ok, did some testing. 3 minutes 30 seconds to 215C. Top temperature around 330C or so in another minute or so. It bounces aronud a bit between 225 and 235. I had one measurement around at 239C. I ran it on top of a marble slab, there were reviews that the feet get hot, and I believe them.
            Hard to argue with the price on this one. I'll have to go through my projects and see if I need to reflow anything.
              • 31294
              i put mine on threaded standoff posts so it is a good inch from the table
              • diif
                • Feb 2014
                • 6978
                • England
                #27
                Mine rests on a silicone soldering mat. I have two large heatsinks that are the same height that sit either side to provide better support for strips. I have also got disc cut from the insulation for a log burner, good for over 1000c
                  • Jul 2011
                  • 6070
                  Were these test at 120 volts or 240 volts which version do you have that you did testing on
                    • 31294
                    pretty sure he used 120v, because at 240v they heat a lot faster than that!
                    • clearchris
                      • Dec 2013
                      • 687
                      Yes, tested at 120v.
                      • redwire
                        • Dec 2010
                        • 3912
                        How are people getting the hot pc board off the plate? My luck, I would bump it and have parts all over the place. There needs to be a lift or something?
                        clearchris, can you measure ohms cold and hot of the plate you have. I ordered one 100V for $9 and will compare when the slow boat comes in.
                          • 31294
                          i have an inline switch on mine that was intended for a table lamp.
                          i just power it off and let it and the pcb cool together usually
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #33
                            I do strips, so there is extra support both sides of the plate and then I lift it with these. https://www.aliexpress.com/item/1005003324153934.html
                            • clearchris
                              • Dec 2013
                              • 687
                              Link? Which one?
                              I can't measure right now, my meter is across the country. I may pick up a cheap meter in the meantime though.
                              • megaraider
                                • Jul 2015
                                • 307
                                • Portugal
                                #35
                                Those gloves don't provide any accuracy
                                Even an aluminium foil paper sheet would provide much better results.
                                Place the sheet over the heat plate, leave good margins, place the strip, do the work, lift the strip picking up the aluminium foil paper edges.
                                If quick cool down isn't needed then follow:
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  #36
                                  Those gloves work great. I'm moving a hot pcb a few cm. I'm. Puzzled how you can tell me thy don't work when they work great?
                                    • Jul 2011
                                    • 6070
                                    • megaraider
                                      • Jul 2015
                                      • 307
                                      • Portugal
                                      #38
                                      Working with LED strips... not imo.
                                      But if those gloves work great with pcb boards there's possible answer to your question @redwire
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #39
                                        [QUOTE=megaraider;1082744]Working with LED strips... not imo./QUOTE]
                                        Yes, mainly aluminium with the occasional fr4.
                                        Whilst the OP and others might claim they are new, I've had mine since 2018, how long does it take you to find an optimal way of working with a tool ?
                                        • megaraider
                                          • Jul 2015
                                          • 307
                                          • Portugal
                                          #40
                                          Agree, LED strips and tools to work with aren't new
                                          • Ady2017
                                            SMD fuse soldering advice please
                                            by Ady2017
                                            Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
                                            11-07-2025, 12:03 PM
                                          • Azurain
                                            Elitebook 840 G5 Bios Chip Soldering Question
                                            by Azurain
                                            I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                                            Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                                            04-14-2023, 06:58 PM
                                          • rmjimenez455@gmail.com
                                            Sumsour station 8586D error H-E
                                            by rmjimenez455@gmail.com
                                            Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                                            09-07-2024, 09:33 AM
                                          • blero
                                            Repairing cheap chinese Led bulbs
                                            by blero
                                            I'd like to try to repair these corncob shaped chinese bulbs with tens of Leds on them.
                                            I know they're bad quality and fail fast, because of the Leds or the capacitor(s).
                                            So I plan to try to replace the main capacitor 15uF-400V with a good quality one.
                                            I've used in the past some capacitors of this eBay vendor which is well known on this site: egekecu. I'm still daily using a monitor I repaired with his products.
                                            I know it has been said he sells good and real brands but outdated capacitors. He's actually 3 times cheaper than RS-Online...
                                            01-31-2021, 07:06 PM
                                          • Peter_1402
                                            Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                            by Peter_1402
                                            Hi Everyone,
                                            I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                            1. Soldering iron works great
                                            2. There is a burnt mark on the hot air gun handle.
                                            I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                            Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                            Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                            Reed switch tested ok with a magnet.
                                            From the above test, I can conclude...
                                            07-12-2025, 11:50 AM
