How Long
  • Berne
    • 13
    How Long
    Hi All,
    I just installed two 1500uf 16v Pansonic Caps to my four year old GIGABYTE board....this was my first ever recap....I think the first went OK
    ( solderwise ) i.e. the solder looks well applied and that 1st cap is solid with no give, the second solder application is fair but that cap has a little give.
    Upon first boot the POST went well and current all around sys performance is noteably better than has been for a long time.
    How long before I can be confident that the two caps are functioning correctly?
    Regards,
    Berne
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: How Long
    i usually run some memtest86+ for a few passes and check there are no memory errors. others run stress testing utilities for hours or days, some even stress the motherboard further reducing airflow while stress testing.
    then once it passes its good
    doesnt sound good if the cap has a little give.
    • Berne
      • 13
      Re: How Long
      Enough said, thank you.
      Berne
      • szreder6
        HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
        by szreder6
        Hello guys,
        I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
        What I did:
        - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
        As far as I know the laptop was in another service center...
        11-22-2024, 05:17 PM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • Phuong_Vu
        Please help me, Please give me the gigabyte Z87p d3 boardview diagram
        by Phuong_Vu
        I need boardview gigabyte Z87p d3 to repair
        whoever has please give me thank you very much
        09-13-2025, 12:41 AM
      • Ferimonka
        HP Envy 15-FH0501sa 3 long 2 short capls lock light
        by Ferimonka
        Hello guys,
        As per title says I have a Envy 15-FH0501sa , Ryzen 5, 16 Gb version.
        Motherboard number is JPB51 LA-M798P rev.1.0
        SN CND3362R3S
        The laptop is getting power and funs stop spinning after few swcconds. It was liquid damaged so we get it to turn on. However 3 long and 2 shor Caps lock lights showing. Power button turns the laptop on but not off.Battery is charging.
        Please help and advice. I attachet the bios dumb in case the bios is the problem.
        Many thanks.​...
        04-29-2025, 02:17 AM
      • Gjackson
        Ps4 Pro long blue light of death
        by Gjackson
        I have an NVA-001 Ps4 Pro with long blue light of death, visual inspection looks fine apart from dust and the very dried thermal paste which I cleaned and replaced, I scoped the board around for any shorts on capacitors and there were none, no blown fuses either. Looking under a thermal camera, southbridge gets warm along with APU and phases for the APU. I cannot tell if RAM is too cold? maybe not powered? but RAM chips are all the same temperatures. At this point I removed NOR and enabled UART to diagnose further. The only thing I get from UART is this following message:
        08-21-2023, 02:41 PM
