Inexpensive Bench Power supply
  • smason
    • 1652
    Hi all. I'm wondering if there is a reasonably priced supply out there.
    Some of the name brand ones seem very pricy.
    I've never really thought I needed one, but lately I'm just annoyed enough at jury-rigging batteries and croc clips, or dragging my Astron RM35 around, that I thought I'd look into it again. Looking for variable voltage/current limit.
    I see a few $80.00 ish Chinese units out there. Too crappy?
    Any suggestions?
    Yes I could build one, but it wouldn't be pretty, and... I'm lazy.
    Thanks,
    Steve
  • etnietering
    • Apr 2009
    • 379
    Re: Inexpensive Bench Power supply
    You might be able to rig up something like this http://www.wikihow.com/Convert-a-Com...b-Power-Supply if you have an extra computer power supply sitting around. You might want to add a high power resistor to both the +12v line and the +3.3v line.
    • smason
      • 1652
      That's a good idea, I have seen it before, however I do want something a bit better. Variable (I do need 6v and 9v occasionally), with meters, and adustable current limiting.
      • smason
        • 1652
        This one looks tempting:
        http://www.dealexcel.com/old/dz-ps30...oduct-430.html
          • 31198
          how much current?
          look here:
          http://tuxgraphics.org/electronics/
          • Krankshaft
            • Jan 2007
            • 2328
            I have one of the Chinese ones a Mastech HY3005 looks smiliar to the one stj posted above accept without the HI / LO switch. It's variable up to 30 volts at 5 Amps. It's pretty nice with a white LED backlit display.
            The first thing I did of course is replaced the Pyramid SNE brand caps on the secondary and the knockoff Chemicon both on the mainboard and behind the banana output jacks.
            Other than that it looks well built the 5 amp model even utilizes a torrid transformer. The 3 amp model utilizes a standard E frame one.
            One thing to remember make sure you get a linear and not a switching supply.
            The linears cost a bit more but they're worth it. I'm pretty sure the Chinese switchers won't filter out the high frequency noise that well you won't have that problem with a linear.
            • smason
              • 1652
              Originally posted by stj
              how much current?
              look here:
              That's pretty cool. A few interesting things on that site, thanks.
              • smason
                • 1652
                Originally posted by Krankshaft
                I have one of the Chinese ones a Mastech HY3005 looks smiliar to the one stj posted above accept without the HI / LO switch. It's variable up to 30 volts at 5 Amps. It's pretty nice with a white LED backlit display..
                Cool. Thanks for the info.
                I spotted one on Ebay in Canada, so I grabbed it. We'll see how it goes.
                • smason
                  • 1652
                  Got it today, looks good, seems to work well. Haven't scoped for ripple yet.
                  Interestingly, it looks very similar to an Instek branded unit I saw in our local "holy crap that's overpriced" electronics supply place with a $289.00 price tag.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • shamsudeen
                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                    by shamsudeen
                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                    07-19-2025, 07:14 AM
                    03-31-2024, 02:12 PM
                  • rabsonnjala
                    LENOVO IDEAPAD 100 works only on bench power supply
                    by rabsonnjala
                    Hie I have a Lenovo laptop
                    Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                    it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                    below are my readings
                    with the original charger only
                    JBATT1
                    PIN1 0.22V
                    PIN2 0.22V
                    PIN3 0.45V
                    PIN4 0.45V
                    PIN5 O.43V
                    PIN6 0V
                    PIN7 GND
                    PIN8...
                    11-20-2021, 08:32 AM
                    07-01-2024, 06:34 AM
