I need UNI-T 260b firmware
UTİ 260B Thermal Imager
Re: UTİ 260B Thermal Imager
uni-t 260b firmware download <—(Google this )
https://www.uni-trend.com/html/produ...s/UTi260B.html
This is in the manual for this device
Is there a reset button on this device
“ To restore factory settings:
1) Press the up/down button to select the Factory Reset option in the System Settings
submenu.
2) Press the SET button to enter.
3) Press the up/down button to select Yes.
4) Press the SET button to confirm.
5) Press the back button to exit.
Note: During the factory reset process, please do not force other operation to avoid program errors.”Last edited by sam_sam_sam; 03-21-2021, 05:41 AM.Comment
The file is on there website link
https://www.uni-trend.com/html/produ...s/UTi260B.htmlLast edited by sam_sam_sam; 03-21-2021, 01:44 PM.Comment
How much of a charge does this unit have it could be that if it below a certain point it might not let finish booting but this is just a guess
But I have seen some devices do this where either it will not boot at all or it will only partially boot
Or there is something wrong with firmware installation or setup
If you can not figure out what going on then if this device is new get with the seller and find what can be done to resolve this issueComment
it's a RAR file, not a zip file.
install this for archive opening:
https://peazip.github.io/
no need for any stupid shit like patches or serials - it's open-source.Comment
Hey Buddy! Did you found a Solution for your Problem? I have the same Problem. My UTI260b can't finish booting. With 100% he stops and that*s all. With completely low Battery i can start him somehow but not always. I have really no Idea what i can do and serching for new Firmware wasn*t succesfull. Thanks for Answer.Comment
I talked to the authorized dealer and they exchanged it for a new one.Comment
by sam_sam_samI saw a review for this UNI-T 260B Thermal Imager and his review was positive but I would like to know if anyone on this forum has used and what they think about its quality and how easy it is to use
Or this model
UNI-T UTi85H Infrared Thermal Imaging Camera 30℃ - 45℃ Infrared Thermometer -
by WoodsworthI have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
START
Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response... -
by Francesc V.Hi:
I have this thermal imager that stopped working. It....
- Switches on
- Displays "normal" image
- It doesn't show any thermal image
Not sure where to start looking at.....any idea/suggestion?
The asset has 3 different PCBs.
Regards,
Francesc....11-28-2022, 06:06 AM -
by GcnewbieForgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
I opened the...03-29-2024, 06:55 AM -
by Veyron7887Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
- Loading...
