Would anyone recommend this “ UNI-T 260B Thermal Imager” feedback wanted
    • Jul 2011
    • 6070
    I saw a review for this UNI-T 260B Thermal Imager and his review was positive but I would like to know if anyone on this forum has used and what they think about its quality and how easy it is to use
    Or this model
    UNI-T UTi85H Infrared Thermal Imaging Camera 30℃ - 45℃ Infrared Thermometer
  • brethin
    • Dec 2008
    • 1907
    Re: Would anyone recommend this “ UNI-T 260B Thermal Imager” feedback wanted
    You don't say why or what you want a thermal camera for so it's hard to help, generally they are a waste of $
      • 31294
      review:
      https://www.youtube.com/watch?v=h3Hu_op4mG8
      • ngml
        Repair of an LG split AC system indoor unit PCB
        by ngml
        I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
        This indicates an error in the communication between the outdoor and the indoor unit.
        The outdoor unit is fine, so the problem is the indoor PCB.
        The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
        I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
        Does anybody have the schematics of this board,...
        02-01-2025, 12:55 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • DrDos
        Unit runs but no speaker output kenwood KR-6030
        by DrDos
        I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
        09-14-2025, 09:57 PM
      • nobbnobb1
        Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
        by nobbnobb1
        Hi guys,
        Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
        When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
        02-03-2022, 11:14 AM
      • ay_bulut
        UTİ 260B Thermal Imager
        by ay_bulut
        I need UNI-T 260b firmware
        03-21-2021, 04:08 AM
