Re: New tool to find short capacitors on motherboards : shorty with display
Some more info about?
I mean about voltage regulator.
Thanks @stj
That's what i usually do, but the outcome -time to arrive- varies widely. [Portugal, Western Europe]Leave a comment:
just ali-express sellers in general.Now you left me curious...
From my experience (couple of hundreds or less) i always got the feeling the sellers were only playing around with the items price and shipping cost (except for express delivery, of course).
Would you mind sharing the site url... (not plain text
just dont use super cuano shipping!!
i opt for ali standard or saver shipping.Leave a comment:
I received the pcb some times ago. but there is a failure I did not find until now.
I made some changes in the schematic, using a constant current source for better repetability,
well I'm still investing. the voltage regulator is giving 2.4V instead of 5V
... and it does not seems to be a short circuit !Leave a comment:
i also have all the parts , now i just need to find time to build it
the chinese shipped all the shit real fast though.
funny how actually paying for the post has that effect!Leave a comment:
Any news on when the PCBs will be ready? I have all the parts here now and I'm keen to try building oneLeave a comment:
Keep the project updated, I would like to buy one when possibleLeave a comment:
OK I'm ready to buy once you have the PCB available. ThanksLeave a comment:
sure !
http://kripton2035.free.fr/Projects/shorty-display.htmlLeave a comment:
Do you have a website with more info on please?nice to see other variations around my project !
the pcb is ready to send to manufacture (for prototype and test only). should receive it in 2 weeks. then test it and if it is ok manufacture in greater qty.
it should cost EUR 10 with untracked shipping, and EUR 15 with tracking.
there will be an order button on my pcb page of the project.
for now, the last variation of the pcb.Leave a comment:
for now, the last variation of the pcb.Attached Filesif you find these attachements useful please consider making a small donation to the site
What would the cost of a unpopulated board plus shipping costLeave a comment:
Hy, there is my 'producat' or copy of Kripton2035/Shorty with little modifications/add , hardware an sofware. I replace AD8628
with LTC 1050 and work fine. From five of LTC1050 , only one give good results of measurement - offer high precision on low ohm value or high ohm value on this device. I used Atmega328, not Arduino. Have fun with work !
For me was, a lot!
sorry only bare pcb for now. may be later a smd-only populated pcb if there is interest.Will you be offering this in kit form if so what do you think the cost would be
you should be able to get all the components for less than $20Last edited by kripton2035; 03-10-2021, 04:32 PM.Leave a comment:
Thanks againLeave a comment:
Thanks kripton - I wanted to order the components I don't have in stock so they are here on the slow boat from china by the time your PCB is ready. Really it's just the AD8628, MCP3421, OLED display and Arduino nano I need to get. Everything else I think I have.Leave a comment:
@dicky96
yes I use the ad8628 in the sop-8 package for my pcb. (and the mcp3421 in sot23-6)
anyway as I will publish the kicad files (schematic and pcb) once the pcb is ok
you will be able to change the package if you need it.Leave a comment:
i'v seen the F411 blackpill,I'd think the speed might help, but maybe not, I haven't read the code, but I rarely run out of ram or flash on these small devices.
https://www.raspberrypi.org/products...pecifications/
>Dual-core Arm Cortex-M0+ processor, flexible clock running up to 133 MHz
Ugh. Now I have to deal with threads on a tiny mcu. I think I'll pass on this one for a while, I'm pretty bought into the stm32 ecosystem. Speaking of which, I think this was recently released, it's a version of the blue pill with stm32f4 processor, usb c, and space for a flash chip on the underside. I might grab a few.
https://docs.zephyrproject.org/lates...doc/index.html
but you may as well spend a bit more for a nucleo64 with the chip on.
then you get more i/o and an st-link programmer/debugger module.Leave a comment:
by aaronkatriniHi all,
Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second... -
by snow_sg1Hi,
First : I've got a SMD rework station, thermal camera and good soldering station
This is my first "short" motherboard repair, this laptop was 25€ so no loss, it just for learning. I want to learn how to fixed board because I want this to become my job.
I've been fixing electronics for 15+ years, but mostly VCR and camcorder.
So, I checked power adapter pin to ground, no short, then I plugged the charger in, light on charger blink indicating short.
PQ19 mosfet got HOT straight away (viewed on thermal cam). Checked,... -
by ProttHello!
Recently I have a problem finding a dead short (as far as my cheap multimeter is concerned) on a multilayered (12 layer) PCB. It is caused due to mechanical stress (warping the board and, I assume, cracking inner layers). Injecting voltage of 0.9 V (operational voltage of that part of the circuit) and drawing 0.5 W doesn't cause any visible hotspot on a thermal camera.
Does anybody have any tips & tricks in order to locate the short more or less precisely? The area has a lot of powerplanes, so it's both blessing and a curse.
Silly idea no. 1: Can I...-
by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
Channel: BIOS Requests ONLY!
by Mess
Hi beginner here, so I'm not sure of I've done this right 😅 trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!... - Loading...
