Signal Tracer - Requesting input on requirements
  • clearchris
    • Dec 2013
    • 687
    Re: Signal Tracer - Requesting input on requirements
    While I was removing and testing caps, I found that the resistor after the amp and before the speaker had broken off. Very subtle, I had looked over it before and not seen it. So, volume has been restored, the speaker sounds pretty good. Tomorrow, I'm going to try out tuning the gain with my newly arrived 2k rev audio taper pot.
    • ugamazing
      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
      by ugamazing
      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
      04-10-2024, 08:06 AM
    • AstutePauciloquent
      Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
      by AstutePauciloquent
      Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
      I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
      11-23-2023, 11:02 PM
    • Xristakis795
      samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
      by Xristakis795
      hi to all
      i have the above model ue40d5003
      the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
      when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
      when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
      Can you tell me from your experience...
      02-09-2023, 03:17 PM
    • howardc64
      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
      by howardc64
      Failure Symptom
      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
      Where is the short?
      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
      05-27-2025, 02:56 PM
    • JayPoorJay
      Converting +/- 5v to a Usable Hz Signal
      by JayPoorJay
      Good morning.
      I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
      This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
      The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
      08-07-2022, 08:35 AM
