Re: Oscilloscope CRT problem
Hello,my name is Afzal!
First I need to introduce my self.
I am from Sri Lanka, and i am also a Electronics Tech / Software Programmer for some years. I do repairs on Computers,PSU,Alarm System panels,CRT /LCD monitors ,and access control card readers,and sometimes X-ray machines etc.The company that I work for does installation / repair /service of security-related electronics equipment for 20+ years. I am 34 years old.
I am studying at the open university of Sri Lanka(I am a late starter) and do my own repair work in my spare time.
I need advice and help on some CRT scopes that had been given to me from the company that i work for as they were removing old items and upgrading equipment.I had managed to some what 'nurse' a very old leader electronics 40MHz 1041 scope from 'death' and is working and is managable!
I hope to contribute to the discussions in the future.
Thank you.
All sorted, the B&K folk have helped me out.
Thanks to all anyway.
CheersLeave a comment:
I've just scored one of these 'scopes on ebay for AUD40 and I got lucky for once. C901 showed no external symptom but once replaced I have a working scope albeit still a little sick. The jpg's in this thread have helped me achieve my success so far.
I'm keen to get this going and I need the schematic. I scoured the net and it seems the one on rapidonline.com has been removed.
Does anyone still have a copy of the file they could email me please.
Many thanks in advance.
BTW the unit is manufactured by Pintek of Taiwan and rebadged by B&K and lots of others. Mine has a Jaytech (Jaycar Australia) badge.Leave a comment:
Are you sure its the CVT, I was also convinced it was that! however it was a component on the output side. I even built a Shorted turns tester to test it as advised on another electronics forum, and it showed the coil as dead! but it really wasn't.
Remember the slightest "drain" on the HV side causes huge current draws on the LV side.Leave a comment:
Well ,thanks for your kind offer ,but my problem was a shorted CVT not an open winding as I deduct from your experience.
Now i am checking some HV ballast for LCD Backlight with not a really good results so far; so as my last resort build a HV power supplyLeave a comment:
Let me know if I can help any any way etc. hope you come right!Leave a comment:
Ok, just test it and it sits at 20uS per wave, so if my calculations are right this means its runs at 50khz.Leave a comment:
Yes, just measure the primary side of the oscilltor, you may be able to see at the BASE of the transformer driver transistor, I expect it to be aorund 25 (400msec)~30 (333msec)KHz range.Leave a comment:
Great, now please read the frequency of this thing for future repair.Leave a comment:
Its back from the dead !!!!
Don't ask what it was, but here's what I did:
Reassemble the transformer, less one turn on the output side (as I started to strip it...)
Replaced C951, C952 and the Zener.
I cut a "slot" between the tracks on the PCB where the HV had arced before.
Turned it one for 5 seconds and felt Q950, it was cold, so tried it again for 10 seconds, again cold...Mmmm decided to turn it around and look at the screen and I couldn't believe it..... A green dot! Almost fell off my chair!
So perhaps those who have had the same problem could try the same?
Thanks for the input....
A very happy person!Leave a comment:
Its a Ferrite core transformer, with a E I configuration, it has a small peice of plastic between the ends of the "E" and the "I" creating about a 1.5mm gap.Leave a comment:
Any one has the pictures of this transformer, I wonder if it is Iron core or Ferrite core, that will give us some idea what frequency it is running at.Leave a comment:
Maybe if someone having a good 2120 can check the oscillation freq.
with a 1000VAC CCFL directly to the doubler probably works tho.Leave a comment:
The hard part will be finding High speed Diode with 1000V rating, the secondary side of the Inverter transformer is isolated (of all teh one I repired so far).
The SCH of B&K shows 1N4007 1000 1A Genaral purpose Diode, so the Oscillator frequency must not be very high.Leave a comment:
CCFLs output are normally at HF ( >20 khz ) so i guess if a high speed rectifier( or 3 serial ) and a capacitor in half wave DC can allow - 2kv .Last edited by monpirri; 03-20-2012, 04:09 PM.Leave a comment:
Ok, as I thought, but I'm now wondering if the CCFL inverters secondary winding is also isolated, or if they share the gound? id it does share, could one not just modified the board (cut the track) to isolate it?Leave a comment:
The circuits as shown is voltage doubler circuits that will put out Neagtive voltage with ref to ground, the positive output is tied to ground is generate from the Isolated secondary winding of the transformer, if you take the output of the transformer winding that is isolated from the primary side, you can generate any polarity you want with ref to the ground.Leave a comment:
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by perzyk23Good morning,
I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise.... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... - Loading...
