clearing solder from very small vias
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I'm trying to fix this satellite receiver. it has an expensive subscription on it that I can't transfer to another box
    Basically the owner has broken the HDMI connector
    I have another reciever of the same type that is blocked (so I can't put a subscription on it)
    I've successfully desoldered the HDMI connector from that one. The connector came out just fine. However I can't clear the solder from all the small holes. I'm practicing on the blocked box, but will then have to do this on the active one to replace the HDMI connector
    I've tried a few techniques that I know but I'm getting nowhere fast
    I've tried wicking out with flux and solder braid and managed to clear a couple of holes but it isn't very successful
    I've tried a manual solder sucker but it doesn't work
    I have some stainless steel needles but even the smallest guage in the set is too thick to go through these holes
    I've tried tinning the holes with 60/40 and then tapping firmly on my bench but it doesn't work
    I consider myself pretty good at micro soldering but I suspect I am missing the correct technique in my arsenal of soldering knowledge
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: clearing solder from very small vias
    have you tried drilling them through ?
    • diif
      • Feb 2014
      • 6978
      • England
      I add lots of 60/40 hopefully getting it mixed with the lead free, remove as much as I can with Chemtronics braid, more flux and my iron and then hot air from above with the solder sucker underneath to clear any remaining holes.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        You need a decent through hole solder extraction system to deal effectively with this, I use a Pace SX-80 or SX-90 for rework such as this. Should there be a problems with very large thermal masses then hot air from one side and solder extraction system on the other
        If this is not an option then remove as much solder as you can and carefully drill out the remaining material or find some one local to you whom can do this for you.
          • 31063
          pre-heat the area with hot air,
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            Would heating with hot air or soldering iron until solder is molten, then using a compressed air duster can to blow the solder out, do the job?
              • 31063
              no idea, it may just cool the board.
              i did wonder once if melting the solder with a vac cleaner hose on the other side would work, but never tried it.
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                There's one way to find out then.......
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Use good solder braid with solder wick inside it, or add lots of wick to it.
                  Cover the holes with lead-solder.
                  Use the biggest tip you have (more thermal mass) and try the braid again.
                  P.S: If the soldering iron does not measure the temp inside the tip just set it to the highest temperature.
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    Usually works for me, but ain't fast... repeat 3 to 4 times per hole.
                    imo, neither compressed air duster or vac cleaner hose will work because the solder will cool even faster
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      In the end I did it (on the faulty PCB) but with a couple of lifted pads.
                      Mostly I used the addition of some more 60:40 plus heating the area with my heatgun then solder wick dipped in rosin and my soldering iron.
                      That went OK but there were 5 problematic holes that I eventually managed to clear by using the legs of a small resistor that were narrow enough to pass through the holes
                      So due to the repeated heating and clearing that's where a couple of the pads got damaged
                      It was very time consuming and not a total success in the end so I wouldn't like to do this the same way on the good PCB.
                      I would really like to buy the Pace MBT250 + SX100 but it's expensive and I've been investing a lot of money into the business recently and I have to stop somewhere. Shame because I used the origianal Pace desoldering tools back in the 80s and they were really excellent.
                      Would something like this do the job? It's 90W so that sounds reasonably useful.
                      https://www.aliexpress.com/item/3290...chweb201603_55
                      Also I could get one of these to preheat the board from below and that should help. These are cheap too
                      https://www.aliexpress.com/item/3301...chweb201603_55
                      I much prefer the wand type desoldering tools but this is affordable and I'm not doing this type of work every day. Most of it is smd.
                      best regards
                      Rich
                      • gabiz_ro
                        • Mar 2011
                        • 167
                        • Romania
                        Try sharpened wood toothpick or some 0.5 0.3mm Pencil Lead Refills if fits.
                        Hot air station and or hot air gun (with some nozzle) to blow away solder
                        • dicky96
                          Sun Seeker
                          • Mar 2017
                          • 1825
                          • Spain
                          Hmm I'm leaning towards getting one of those solder sucker guns I posted in #11 and one of the Kada preheaters as well
                          They seem to have some good reviews on Aliexpress. Has anyone here used that one (or equivalent)?
                            • 31063
                            the desoldering station is made by zhong-di, and sold under many names.
                            they are pretty good - i have a similar one.
                              • Jul 2011
                              • 6040
                              I have a few of them as well they work fairly well
                              I do have have a recommendation for you and that this
                              Buy extra tips and filters for the Desoldiering station when you buy it you will need them
                              • dicky96
                                Sun Seeker
                                • Mar 2017
                                • 1825
                                • Spain
                                Thanks guys
                                I've ordered the SS-331H vacuum desoldering stations and one of the Kada 853B Hot air preheaters as well
                                Hopefully these will be a useful addition to the workshop. I'll know in about 3 weeks when they come from China
                                • dicky96
                                  Sun Seeker
                                  • Mar 2017
                                  • 1825
                                  • Spain
                                  I've also added a couple of these to my order
                                  https://www.aliexpress.com/item/3255...chweb201603_55
                                  They look like they would be useful, and so cheap too.
                                    • 31063
                                    i also recomend an inline filter to protect the pump,
                                    i linked a banggood one in an older thread.
                                    like this:
                                    https://www.banggood.com/Universal-P...-p-993094.html
                                    • dicky96
                                      Sun Seeker
                                      • Mar 2017
                                      • 1825
                                      • Spain
                                      Thank stj that looks like a good idea. and so cheap they practically give them away
                                      Bit like living here large beer..... 1.50 euro
                                      • m4a2t0t
                                        • Mar 2013
                                        • 276
                                        Is there a reason you dont just heat the board up with a hot air gun until the solder liquefies and then push the connector through the holes? You can put fresh solder on all the pins after.
                                        Those little pins love to come off when you try and desolder them . I would use a micro hand drill before I tried desoldering them but I would just heat the board and put the connector on first.
                                          HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                                          This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:44 PM
                                          HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 03:36 PM
                                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          09-12-2024, 03:28 PM
                                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
