Restoring a HP 3466A DMM... Where to get banana jack with fuseholder?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I got an old HP 3466A DMM. My second only True RMS DMM.
    This DMM is in fairly rough shape. The buttons are pretty messed up, but that's somewhat straightforward. However it's missing the current measurement jack that holds the fuse. Where could I get one of these ... or perhaps jury rig something that would work as such?
    Looks like people have had the same question in the past, probably will need to jury rig. It's HP PN 5060-7455 ...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Restoring a HP 3466A DMM... Where to get banana jack with fuseholder?
    And just as a rant... I know why they have shrouded banana plugs, I just hate them because it obsolete old banana jacks until you cut them off...aaaahhh... need a set of probes without shrouds...
    ... and this DMM uses a lead acid battery... interesting... unfortunately the battery is well past sulfated now.
    • valvashon
      Samsung UN55FH6030CXZA main board USB jack indentification
      by valvashon
      Samsung UN55FH6030CXZA main board, BN41-01894, bad USB jack. Jack is mangled and needs replacing with like. Jack is marked "Simula" with the number 130318. Search for Simula turns up a weak looking website of a company that seems/seemed to supply USB jacks and other USB technology but no current items turn up for sale.
      I should be able to research and find something applicable through a Digi-Key search after I unsolder/cut out this one and measure the mounting/pin connection pattern on the board but I thought I'd ask here to see if anybody knows of an exact make/model...
      01-23-2025, 11:17 AM
    • diamon
      Dell 5590 LA-F412P does charge with USB-C not with DC-Jack
      by diamon
      As mentioned, I have a Dell 5590 laptop with motherboard LA-F412P.
      This laptop works with the USB-C charger and not with DC-Jack charger.
      With the USB-C charger attached, the battery is charging and in the BIOS the charger is also recognized.
      With the DC-Jack charger attached (USB-C charger removed), the light of the charger is not going off and the BIOS does not see the charger (message AC Adapter = Not installed). I'm using original Dell chargers and I have tested the used chargers on other Dell laptops and they are working correctly.
      I have replaced the DC-Jack,...
      12-29-2023, 07:29 AM
    • paparazzo79
      3.5 mm headphone jack missing
      by paparazzo79
      Hi guys,
      I purchased used MSI GE 73 Raider laptop used from a guy.When laptop came home I noticed that there is no "golden circle connector" on the headphoner jack (pic below).
      I contacted the seller, he told me like it was there and it probably fell off.
      I am not dumb, is he lying to me or it is possible that in the shipping it really fell off?
      Oer laptop is missing whole connector.
      The headphone jack works normally,I have tested it with headphones....
      05-20-2025, 08:48 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • lowpost99@gmail.com
      Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
      by lowpost99@gmail.com
      I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
      09-03-2024, 02:57 PM
