Crimping crimp-on RG58, RG174, etc. connectors without die?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I've seen these really specialized hexagonal die crimpers for RG58, etc. crimp-on connectors. I wonder if anyone has been successful crimping these things without the special crimper?
    I've come across many RG59/RG6 crimpers which does me no good...or maybe they could?
  • redwire
    • Dec 2010
    • 3912
    Re: Crimping crimp-on RG58, RG174, etc. connectors without die?
    I've never been able to cheat using a die-crimp on coax. RG-59 rings I have mangled and fudged with pliers, not a decent option.
    You need to crimp in a concentric (circle), not like spade crimp connectors.
    Dies are $6 a set and the tool $16,
    https://www.aliexpress.com/store/pro...23703640.html?
    HEX die
    RG-6 8.1mm
    RG-59 6.5mm
    RG-58 5.4mm
    RG-174 2.6mm
      • 31196
      how do you crimp the center pin?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        The center pin can be soldered for me, no problems with that. I just wonder if it's possible to cheat crimping the main connector. Sounds like I have to get a crimp tool.... ugh.
        Mainly because there are so many kinds of cable out there... though I think the main ones I need are RG8 RG58 and RG174. I suspect that RG59 most connectors out there are the compression type as the industry uses so much of it they're cheaper...
        I've seen some second hand RG6/RG59 crimpers around, wonder if it's worth picking up one though I don't need it... the others are the ones I really want.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          You know, technically I just need the die... then I can stick it in my vise...
            • 31196
            they dont usually use a die, they are single function - i have one from the cable scumbags.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Well depends on the type, yes, the RG6/RG59 ones I've seen are indeed single use and hence useless... Likewise the compression tool...
              but there are the die based ones, of which I need to acquire the die.
                • 31196
                try aliexpress.
                • megaraider
                  • Jul 2015
                  • 307
                  • Portugal
                  Usually the center pin is the inner copper wire itself stripped from the coax cable.
                  (Not sure if that was the question, though)
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    Me neither.
                    But since i only do it very occasionally never bored to buy the crimp tool.
                      • 31196
                      center pin is silver plated brass on BNC's,
                      the only connector that uses the internal conductor as the pin is an "F" connector.
                      and those are 75ohm and only used for tv(inc sat & cable feeds).
                      and for F connectors the twist-on ones are best.
                      • redwire
                        • Dec 2010
                        • 3912
                        There are some RG connectors with a screw-on threaded collar, so you don't need specialized tools.
                        The crimping tool (coax) dies pay for themselves when you make BNC-BNC test leads and cables. Also need something for Molex pins or crimp connectors sometimes.
                        The Ali store sells 44 different kinds of dies. Wow.
                        • llonen
                          • Sep 2014
                          • 495
                          • hampshire
                          I make up a lot of these cables for people and have never found a decent crimp tool for RF connectors, and never had any success with the compression types. I once brought a 100 of the %^$*&^ things from a local supplier and got nowhere with them, took the lot back to the supplier with cable and asked them to make up a set. That was an epic fail hence I don't use crimp or compression types.
                          If some one does come up with a decent crimp tool for RF connectors point me in the direction please.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Yeah, most of the screw on connectors cost $ARM$LEG. Grr.
                            On the other hand, I thought the RG59 compression connectors were really consistent (because so many are made/used, they had to get it right for the cable layman.) Crimp connectors, on the other hand, take forever to put together and touchy, especially if you didn't cut and strip the right lengths...
                            I might end up having to buy a crimp tool as there are no cheap compression connectors for RG58, etc... Sigh. Just need to find one that supports all the cables I could possibly need with the minimal amount of dies.
                              • 31196
                              this whole thread is pointless unless someone actually names the connector type rather than the cable.
                              FFS, i could terminate rg59 in a terminal block!
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                BNC crimp, N crimp, PL-259 crimp, whatever - they all use the same collar when dealing with crimps - depending on the cable!
                                I don't think terminal blocks come with crimps and the SWR would be miserable.
                                  • 31196
                                  well they all have a center pin - the pl259 is a solder job obviously.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    In all these cases, the center pin is not a problem with ad hoc tools or even solder if it comes down to it (unless the connector was designed to be soldered, then your choices are limited.) The problem has always been dealing with the shield, namely, crimping it.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      GRR... I just chanced upon a ratcheting hand crimper tool with a die I don't need... seems that the dies may not be interchangeable between the different tools even though they look so much alike?
                                      Anyone used them? What brands are out there? Could they be jury rigged to fit?
                                        • 31196
                                        every company uses there own spacing for the die screws/clamps.
                                        if i ever but another crimp tool it will probably be an "Engineer" brand.
                                        but they arent cheap.
                                        • CapLeaker
                                          Crimping CAT7 connectors high failure rates
                                          by CapLeaker
                                          I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
                                          Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
                                          11-09-2024, 04:11 PM
                                        • Eniaro
                                          Are USB C connectors standard
                                          by Eniaro
                                          I have a number of laptops with damaged USB-C connectors.
                                          I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
                                          I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
                                          I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
                                          07-24-2023, 03:07 PM
                                        • corrize
                                          Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                                          by corrize
                                          Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                                          There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                                          I have :
                                          - hot air, and a
                                          ll stuff around
                                          - true kapton tape
                                          - 140 and 180 degree soldering paste
                                          - bismuth
                                          - little hot plate 250 degree max
                                          - the new BGA chip with probably
                                          05-20-2025, 01:26 AM
                                        • corrize
                                          How to clean fpc connectors oxydated ?
                                          by corrize
                                          Hello, do you know if it is possible to clean oxydated fpc connectors until it back brilliant please ?
                                          I know the best is to replace, but sometime micro fpc are very little oxydated and very hard (or unable) to find as new. So, there is may be a chemical product for that ?
                                          I use vinegar for rust on metal screw or little metal pieces and I finish with WD-40 for protect, else the rust can come back. That works pretty good.
                                          I not yet tryed on connector. Do you have a good method please ?
                                          10-20-2024, 07:29 AM
                                        • fuzzy4
                                          Identify Cable connectors
                                          by fuzzy4
                                          Can someone identify the connectors on this cable and what it's used for?
                                          I recognise the BNC and what looks like power.
                                          The middle connector, is a BNC adaptor.
                                          Thanks...
                                          09-08-2024, 02:37 AM
