Aneng 8008 fail :))
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Aneng 8008 fail :))
    Good day folks. This should definitely be in the Off-topic category because it's just so stupid
    Today I was messing around with a PIR sensor for a large outdoor LED floodlight which doesn't work. As always, I was using my Aneng 8008, since this shop gave me bupkis to work with...damn cheapskates....AAAANYWAY....and I first wanted to make sure there's line voltage actually coming into the damn thing. There's a capacitive dropper PSU commonly found in small low power electronics like these. Put my probes on the lives wires, numbers jumped around a couple of times but that was it - no power at all. Ok, simple job, probably a bad mains cable I thought. Unplugged the thing, set the good ol' Aneng to ohms and probed between each prong of the AC plug and its respective wire on the board....0 ohms...WTH ?!
    Plug it back in and probed again thinking perhaps the socket is a little loose and didn't make contact. Again: no matter how much I jimmy-jammed those probes on those wires, I got nowhere close to a correct reading. Wiggled the plug a couple of times, stil nothing !
    Unplugged it again and this time poked my probes right into the 230v socket holes...gave them a good jiggle, numbers jumped around but same story...did my meter just die on me ?! Grabbed a battery I had on my desk, probed it: nope - 9v right there...what gives ? Imagine this thing puzzling me for 5-10 minutes to the point where I hopped on Ali ready to order a new meter...until I noticed the little blue select/light button to the left of the dial and gave it a push. The display switched to AC RMS and that's when it occurred to me......Danny you're a genuine dumbass !
    The strange thing is that I could SWEAR I measured AC before and the meter switched to AC automatically, so I was expecting it to do it again here, but apparently my memory is a bit fuzzy...too much solder smoke >_> I never had to use that button very often, given that I mostly work with DC sh!t, but this one time I needed it, I forgot it was there...getting old
    Wattevah...
    • 31200
    Re: Aneng 8008 fail )
    lol
    you can "upgrade" those like the uni-t 210e by messing with the eeprom.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      Yes, but I doubt you can make them switch automatically. Still I can't shake the feeling that I didn't need to toggle between Dc and Ac...a while ago, we were messing with an UPS and when I mesured its output I remember my colleague telling me "switch over to AC", to which I replied "no need to - does it automatically"...am I losing my mind ? Anyone out there with an Aneng who can confirm ?
      Wattevah...
        • 31200
        i have 2, they dont auto-switch
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          Then how come it measured the output of the UPS correctly I wonder ? Either that or I don't remember correctly and our discussion was about the RANGE which is indeed automatic, not the type of current AC/DC...most likely scenario here....
          Wattevah...
            • 31200
            probably because the ups was squarewave, so dc switching polarity as oposed to a sinewave.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              I was just thinking of that, but I though NAAAH, can't be...
              Wattevah...
                • 31200
                well if the invertor in switching at 50Hz then it's well in range - i think the meter can operate upto atleast 10MHz
                • megaraider
                  • Jul 2015
                  • 307
                  • Portugal
                  Switching automatically between AC/DC does not make any sense, imo!
                  Most likely you've measure the PSU without any load and therefore got the reading (testing without any load is useless and misleading, btw).
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    Replaced emmc.
                    Terminal log
                    UART
                    AC_ON
                    E-B
                    FDE enabled
                    06-01-2025, 02:11 AM
                  • C152Heavy
                    Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                    by C152Heavy
                    Summary for TL-DR readers:
                    • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                    • Have obtained Samsung schematic & service documents - Can upload if helpful.
                    • Have read ALL applicable threads
                    • C1818 and CP820 replaced as low hanging fruit
                    • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                    • VCC pin (18) of PFC...
                    01-11-2023, 02:53 PM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • dragometin
                    Hitachi 40HYC42
                    by dragometin
                    TV Model: Hitachi 40HYC42
                    Power Supply: 17IPS71
                    MainBoard: 17MB95M
                    Panel: VES400UNDS-2D-NO3
                    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                    Is there any variants on 17IPS71 power supply's?
                    UART output pins 10 and 12 on scart connector:
                    Code:
                    12:24:04.595
                    08-08-2024, 05:53 AM
                  • Perry Babin
                    Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
                    by Perry Babin
                    This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
                    04-03-2024, 10:40 AM
