Fun Poll: how much solder wire do you have stockpiled at home?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Just solder wire. As I heard someone else say, I think I have enough solder to outlast myself... at least at current use.
    Include:
    - any gauge
    - any flux
    - spooled or spiral (estimate!)
    - Pipe solder wire (make a note of it if you wish)
    Don't include:
    - solder pot solder
    - solder bars
    - waste solder
    Yes I know the US "avdp" pounds vs metric measurements are slightly off, just pick which you use.
    And I forgot to add the metric conversions for the last three options. 2lb option => 1kg option and 4lb => 2kg option.
    21
    Less than 100g or 0.25 lb (less than a spool)
    0%
    0
    less than about 250g or 0.5 lb (small spool) but more than above
    0%
    4
    less than 500g or 1lb (regular spool) but more than above
    0%
    4
    less than 2 lbs (lots of types of solder) but more than above
    0%
    4
    less than 4 lbs but more than above
    0%
    3
    4 pounds or more of solder
    0%
    6
    The poll is expired.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Fun Poll: how much solder wire do you have stockpiled at home?
    I think I have about 2.2 lbs (~1kg) of solder wire, about 0.75 lb (~0.33kg) is pipe solder.
    I have another 0.5lb (~0.25kg) of waste solder I think... haven't weighed it in a while.
    • diif
      • Feb 2014
      • 6978
      • England
      One spool of quality 0.7mm solder
      One spool of Chinese 0.4mm solder a bit crappy
      One spool of Chinese 1mm solder, very crappy and thick but good for removing parts.
      One spool of Chinese 0.4mm low temp solder.
      I just have a lifetimes supply of Chemtronics braid (56 bobbins).
        • 31197
        one 100g reel of 5% silver 0.5mm very expensive stuff,
        about half a 250g reel of 0.7mm pretty expensive stuff.
        but as both are lead-free, there is a lot more on those reels in meters than it sounds.
        and about 0.5L of industrial flux intended for wave-soldering.
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          About 7 pounds (various diameters) of "wire" -- a mix of Sn60 & Sn63 -- and a few tubes of paste.
          Probably 3 pounds of "plumbers solder" as there tends to be more "waste" with that activity.
          A dozen cans of aerosol board/flux cleaner.
            • 31197
            well if we are including cleaner, 10L of pure IPA.
            (only way to get a decent price!!)
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Oh gosh, I totally forgot about paste (and solder balls for bga) and since they are used for construction, I should have included it with this poll. Alas probably need to multiply paste mass by a fraction as I don't want to count the flux/carrier as there's more not-solder in it than in wire solder. Solder balls probably have a go as-is.
              Of what I have, I have that 0.25 lb of lead free electronics solder and a bit less than 0.5lb of lead free pipe solder. Yes I still have leaded pipe solder...
              ... and I have a minuscule amount of solder paste as I don't stockpile enough surface mount components at home to build with...
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                Easier to just "rescue" a case (but, then you have to store it :< )
                  • 31197
                  case?
                  that's in 2 5L containers.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I wonder if my waste solder, if I skim enough of the crap out of it, is good enough to grind down into a powder and mix with flux to make homemade solder paste...
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Surely it will have lead and lead free solder mixed together ?
                      That can't make for an even melting paste, which is super cheap to buy anyway.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Well I can stir it to make it homogeneous, so it shouldn't be too horrible. I suspect it has much more regular lead solder than lead free, maybe enough so that it's close to 63:37 (if 60:40 is primary component and the tin heavy lead free.)
                        Just seeing what I can do with this big lump of waste solder...
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          I just stick mine with any scrap metal I'm taking to the recycling centre.
                          The lead balls are extremely small and even looking if I stick some paste under a microscope. If you think you can grind down your waste to that size without breathing in any particles why don't you try. Seems like an awful waste of time considering the price though.
                          • Curious.George
                            • Nov 2011
                            • 2305
                            • Unknown
                            case?
                            Did you miss the word "aerosol" in my post?
                              • 31197
                              yes.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                And I thought I had a lot of solder, seems a few of you have even more; I guess it's ok for me to stockpile more solder
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8327
                                  I am usually have at least 1lb of solder, no lower than that and as high as 3lb. Different solders and different sizes also silver solder. Depending on how much you repai0r electronics you repair, adjust how much you got on hand...
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    For me, building/creating uses more solder than repairing... I use really minuscule amounts for repair.
                                    This is for home use, one can't expect to do *that* much building/repairing...
                                    • Curious.George
                                      • Nov 2011
                                      • 2305
                                      • Unknown
                                      You're ignoring the fact that you often need different "(solder) wire sizes" for different tasks. Yeah, I guess you could probably buy a small qty (<< 1lb) of a variety of different sizes... if you don't mind rebuying those small quantities (at outrageous prices) often.
                                      Or, you can buy a pound of each of several different sizes and "chemistries" (for want of a better word). It's not like it's going to "spoil" if you don't use it by next Thursday...
                                      As to the amount of building/repairing that might be done, that depends entirely on the individual. I probably repair 4 or 5 dozen monitors in a typical year (not for profit; rather, it's somewhat "therapeutic"/mindless). I use far more solder removing components than installing their replacements.
                                      And, any cabling that needs a more permanent connection (than wire nuts) eats up lots of solder (doing so with 0.4mm solder wire has the iron calling for solder faster than you can feed it!)
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        That's how I would expect people to do it for home use, either buying small quantities of each size (otherwise those small spirals you see being sold) or just feeding a lot of the fine gauge solder wire (which I think is kind of dumb but to each their own.) Also the leaded vs unleaded solder, keeping both around is helpful. In any case, it's the stockpile I wonder about, even if they have indefinite shelf life.
                                        Solder prices also have skyrocketed since last I purchased solder, which probably is another good reason to stockpile. Perhaps it's just the lead free requirements necessarily increasing the price due to tin being the more costly metal, and then vendors deciding to price their leaded solder to the same as lead free just because there's a demand for it. Don't know.
                                        Even if you use a lot of solder to desolder and then more to re-solder, it's still less than soldering a whole new design/board
                                        I suppose I'm also posting this on an enthusiast board versus casuals that may actually buy those small spirals of solder. Now those are quite overpriced.
                                          Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 08:00 AM
                                          Multifix 425-01 and 450-01 Rework Flux Datasheet
                                          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                          - No Clean Formulations
                                          - Low residue
                                          - Range of activity to deal with different component solderability
                                          - Halide free
                                          - Suitable for dispensing
                                          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                          Both products are supplied in syringes or cartridges for application by dispensing....
                                          10-07-2024, 06:02 AM
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • bussincaps
                                          MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                                          by bussincaps
                                          Hello All,
                                          tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                                          Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                                          eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                                          Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                                          I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                                          08-03-2023, 12:57 PM
                                        • petemanuk
                                          BGA solder balls not connecting - help pls
                                          by petemanuk
                                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                          11-16-2022, 05:21 AM
