In cct. BIOS flashing
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    I have a number of mobos which will not POST.
    These are all soldered as opposed to socketed BIOS flash parts.
    I suspect the BIOS image is bad or has bad bootblock or a bad IC.
    With my POST card;
    Mobo 1 - Award
    Attempts a BIOS restore, finds the image on diskette, reads
    it but does not update the BIOS and simply loops through
    the recovery process with no BIOS being restored.
    Suspect bad BIOS IC. Reflash it in the first instance.
    Mobo 2 - Award
    Simply sits a C1 checkpoint. So... it may have an intact bootblock
    but cannot load the BIOS image from the IC.
    Mobo 3 - Award
    The BIOS rdy led is lit and the data LED are flashing
    Suspect the BIOS IC is being accessed but the BIOS IC
    is damaged, empty or corrupt in some fashion.
    Is it safe to flash these in place with a Willem or any other programmer?
    I suspect if so, an adapter would be required to do this or a plcc32 socket
    rigged to a programmer might do the trick
    Any suggestions?
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: In cct. BIOS flashing
    If you have any success with these, please post how you did it
    I've never had any luck with soldered BIOS chips which have corrupted firmware
    If it won't boot into Award boot block recovery, or respond to Ctrl+Home for AMI, it's not worth wasting more time on it in my opinion
    In my experience, these recovery tips from the Net DON'T work
    1. Shorting address line connections to trigger BIOS data corruption
    2. Putting a correctly programmed chip in parallel with the original
    I'm not a fan of Gigabyte, the main offenders for soldered BIOS chips, and not impressed with their Dual BIOS either
    Don't believe you can trust firmware, to recover from an abnormal event where the original (BIOS) firmware has failed
    I believe the new generation of SPI BIOS chips has provision for in circuit reprogramming
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • Agent24
      I see dead caps
      • Oct 2007
      • 5084
      • New Zealand
      I did manage to reflash a soldered in PLCC32 parallel EEPROM on an Asus CD-RW drive but got hardware error from the programmer when trying the same thing on a motherboard (I used a Willem PCB 5)
      I wrote about it here: http://forum.rpc1.org/viewtopic.php?f=13&t=44275
      You can see the homebrew adaptor I created
      The best way would probably be to get hold of a hot air rework station, and just remove the chips.
      Then dump the contents with a programmer, and try to determine if it's corrupt. OR just reflash anyway.
      If you went to all that trouble then you should solder a socket to the board before you put the chip back.
      -David VanHorn
      • lucky13
        • Aug 2007
        • 412
        You know, I thought about how to flash my Gigabyte board that would not POST and I have been looking at these programmers and wondered out loud that why there isn't an adaptor to cover over the soldered bios chip and flash away. Your design exactly illustrates my thought. I like it!
        Did you write down the p/n of the socket and whatever parts you had to buy?
        • Agent24
          I see dead caps
          • Oct 2007
          • 5084
          • New Zealand
          I think it has not been invented normally because unlike serial EEPROMs the parallel ones are not designed to support it (in-circuit programming). Probably just chance that it would work on any given board.
          I suspect the design of the surrounding circuitry would play some part. It worked for me on the Asus CD-RW but not on an Albatron motherboard. However on the CD-RW drive I had to remove 2 SMD parts to get the socket to fit over the EEPROM. Perhaps this was part of why it worked.
          I would test it on some other soldered in PLCC chips I have but they are all FWH/LPC
          The design of my adaptor is simple, there are only 4 parts to it and they should be available anywhere.
          1) PLCC32 Socket (I used standard type, not SMD) (Jaycar)
          2) Prototype board. Similar to Veroboard/Stripboard but without strips. Each hole has a copper pad but none are connected (DSE)
          3) SIL Headers. Snap off to 16 pins long, one each side. (DSE)
          4) Solid-core ethernet cable. 4 x 8 conductors = 32! Perfect. (DSE)
          My adaptor design worked but the implementation is not so good. It was a prototype and I can see there are problems
          eg: accidental short circuit is too easy and solid core cable can break easily (however if you DO build one this way, solid core is the only way to do it)
          If I built another I would improve on the design by making my own PCBs, and using a ribbon cable and headers to connect the two.
          Also, an SMD PLCC socket and/or a handle on the back somehow may help because the one I had did not stay on the EEPROM. It would jump straight off again so I had to hold it down quite hard while I did the programming. Not easy when there's 32 exposed wires in the way and it hurts your fingers.
          Remember that the pinout for the PLCC32 will be flipped and changed around. Also, I had to break one corner off the socket to be able to fit it on backwards.
          -David VanHorn
          • lucky13
            • Aug 2007
            • 412
            I remember when I was studying electronics years ago, someone was making these breakout IC clips that you clamp onto the IC and there are individual pins on the top for you to hook up your scope probe. I think something like that may be easier to use except I don't remember the brand nor the proper technical name. That would elimiate the mods that are described by Agent24
            • Agent24
              I see dead caps
              • Oct 2007
              • 5084
              • New Zealand
              I thought those were only for standard DIL ICs though, not PLCC?
              -David VanHorn
              • lucky13
                • Aug 2007
                • 412
                You might be right...I may have to browse the digikey catalog when I am bored at work....
                • kenkaniff
                  HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                  by kenkaniff
                  Product Name: HP Pro x360 Fortis 11-inch G9
                  System BIOS: U94 Ver.01.08.00 10/06/2023
                  Serial Number: 5CG31946F5
                  SKU Number: 85W05EC#AK8
                  Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                  This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                  I needed to remove bios password...
                  10-01-2025, 04:32 AM
                • Timeeez
                  X270 - Bios flashing help
                  by Timeeez
                  I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
                  Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
                  11-30-2022, 05:17 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
