infrared rework station
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    I would like an opinion on these two machines, the quick 7610 has the top heater to be replaced (300 eur). The main use is the welding of the new processors on laptop cards-
    https://www.ebay.it/itm/Bga-rework-s...YAAOSwmCVY-M5A
    or
    https://www.ebay.it/itm/Jovy-Systems...QAAOSw~QRaCcBW
    I currently use an ir6500, other recommendations on other brands are welcome, I can spend up to 1500 eur
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: infrared rework station
    To be honest, after I've played around a bit with a bunch of various IR reflow machines, I can't say I recommend any of them over a home-brew / home-made machine. If you have a bit of electronics knowledge, you can easily and cheaply make your own machine for a fraction of the cost.
    Also, I recommend going with a hot air setup. IR tends to heat unevenly, even with good high-quality heaters (due to different absorption rates of different components - this depends on the component's surface finish and its color).
    For the bottom heater, the easiest setup I've made was with a gas stove burner - nice even heating and plenty of heat available on hand. No scorching on the boards at all, unlike IR. Same if you go with electric hot air.
    To simplify things, just buy the PID controllers and SSRs/Relays.
    • nguroje
      • Feb 2015
      • 14
      • Nigeria
      hi momaka
      Please can you share knowledge and pictures for the home made machine?
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Hi, It's many years that 'I use my homemade rework station ( I have posted the schematic in an old thread on this forum ) without any problem. (I use it in a repair shop 3 4 times in a day)
        With my rework station (I have spend 250 eur to buy top and bottom heater elstein , two altec pid and two omega thermocouple) and I have no temp error .
        But my idea was to hack a commercial machine because tbe structure is a good start point .
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Originally posted by nguroje
          hi momaka
          I never made one. Was going to, but then ended up using my gas stovetop and my hot air station. That alone allows me to do pretty much any BGA work I want.
          Ah, I see. So you're looking for a commercial machine to use as a "base" for your own machine. In that case, I don't know what to suggest. Again, I prefer hot air over IR, so I can't really recommend anything.
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            it is not easy to weld the new cpu only with hot air stations, following the manufacturer's specifications.
            One of the main problems is oxidation caused by oxygen in the air.
            To solve this and other problems I would like to build a rework machine:
            top heater -> nitrogen instead of air
            bottom heater (1) -> hot air, located under the chip
            bottom heater (2) -> infrared quarz heater wavelengths of 1.5-8 μm or ir ceramic heater wavelength range is 2-10 μm.
            The quick 7610 has the automatic top heater and the space to make all the changes. The jovy is only for small chip, on youtube, many people show how improve the bottom heater power
            • clearchris
              • Dec 2013
              • 687
              That's going to use a lot of nitrogen. I use nitrogen for AC repairs, and there's not much in the tank (40 cubic feet IIRC), nitrogen isn't like CO2 that will liquefy in the tank.
              • dellxps15
                • Feb 2014
                • 1591
                • italy
                hi the quick bga rework in the link say bad top heater... and who knows if eletric pcb is fine.... plus not a well known bga machine for warranty and repair in italy.
                for the nitrogen hot air..... if u use proper profile, flux and so on there is no need of that since bga can support hight temp up to 3 times....
                i would suggest you a good hot air or infrared bga rework already made , so u need to focus on good profiles.
                not only a machine make the good work, but practice and practice is the best thing to get good results.
                rework need some time for heating. lowering that time will make temperature needs much bigger with possible bga damage.
                ps: the other jovy is too small for a good rework. the r7500 is low power.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  With my rework machine after a lot of time I'm reached a good profile and usually the problems regards the difficult to buy a very good bga chip , on ebay 90% are remarked, overheated, etc.
                  This is my usual profie for common chip (not for cpu) .
                  I modify the machine for this software with good results, the top and bottom heater work together .
                  With the first prototype the top heater start only after the bottom heater has reached a certain temperature, usually the activated flux temp
                  • shahnld
                    wds-580 rework station issue
                    by shahnld
                    Good day.
                    i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                    Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                    kind regards...
                    03-28-2024, 01:14 PM
                  • minimania
                    Need Schematic for jbc am6800 rework station
                    by minimania
                    hi all im looking for a Schematic for jbc am6800 rework station
                    mine has stopped working fully
                    it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                    now it wont turn on at all...
                    01-28-2025, 03:44 PM
                  • shahnld
                    Seamark ZM-R6200 Rework station
                    by shahnld
                    Good day Experts.
                    I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                    Kind regards
                    01-24-2024, 10:55 AM
                  • Peter_1402
                    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                    by Peter_1402
                    Hi Everyone,
                    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                    1. Soldering iron works great
                    2. There is a burnt mark on the hot air gun handle.
                    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                    Reed switch tested ok with a magnet.
                    From the above test, I can conclude...
                    07-12-2025, 11:50 AM
                  • petemanuk
                    Help with IR6500 rework station
                    by petemanuk
                    I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                    1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                    2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                    10-14-2022, 12:31 AM
