Re: What is a good de-soldiering iron/tool?
Yes, Expensive but best at that price.
After reading the desoldering forums, I do want to step up to an easier way to desolder than a squeeze bulb or spring method. It looks like a really good and affordable one, is the Aoyue 474A++ Digital Desoldering Station. It is around 200 so I hope it good. I read some reviews that it works OK on motherboards but I was not so sure. This is my main use right now. Anyone use this one???Leave a comment:
https://www.aliexpress.com/item/50W-...868116468.htmlLeave a comment:
I did not realize that you looking for one for a soldering iron
You need to know what is the maximum amperage that is iron is going to take to run it
Now with the ZD-915 Desoldiering Gun with NO controller the amperage is over 8 amps @ 12 volts I did not leave that way for very long because it starts glowing very brightly and burn out
I was doing this test because I trying to use this on battery power I have to work out some problems that I am having with this setup ( the mosfet when up in flames and burn up the iron )
It looks like the controller on this unit was some how use the incoming power to telling controller to control the amperage but on battery power it does not work right because it does not control the the amperage
When I work out how make it work right on battery power I will post it on this forum in a new post stay tunedLast edited by sam_sam_sam; 07-08-2018, 07:16 AM.Leave a comment:
I was asking for a soldering iron the Bakon 950D T12 link some pages was no longer good
kinda surprised you would link to a PSU that generic lookingLeave a comment:
Here is one for you
https://www.ebay.com/itm/AC-100V-240...r=540897323249Leave a comment:
on a side note, so glad i have this de-soldering gun, had to repair a DIY board, i lost a LED, a DS18B20, and 2 GPIO pins; based on the timing i am gonna blame the T-storm
dead led measures 160Ohm resistance and my tester says unknown or damaged partLeave a comment:
LOL, that's just a little derp nonsense from nVidia, but I'll explain.
GeForce GT210 requires nowhere close to that amount of power. 12V @ 18 Amps is 216 Watts of power - that's how much you might expect a Radeon R9 290/X to pull near full load. But the puny GT210??? - Probably no more than 30 Watts, if even that (the GT210 is just a shrunk-down core of the 8400 GS core). The size of the heatsink on it should be a good indicator of that. But I digress, here.Leave a comment:
great point stj! I learned the hard way when i first used my FR300. If i have to add new solder to a joint to help desolder.. i always clean the flux away before desoldering. I havent had a clogged tip since. Its extra work but easier than having to drill out a clogged tip! I cringe when watching youtube vids of repair work when they are sucking up all that gooey flux!Leave a comment:
Only if you use too much flux. Adding fresh solder also has flux in it, so it's the same thing. That's why I prefer to put flux by myself - that way I can precisely regulate how much to apply (very very little - just a tiny sand grain spec on each joint or less!)Leave a comment:
dont add flux when using a desoldering unit - you will clog the nozzle badly.Leave a comment:
In any case, nVidia and ATI just aren't very clear when they specify their power ratings. That 18-20 Amp "requirement" you saw is actually just a recommendation for the whole system. But depending on your CPU TDP and number of HDDs and other devices you have, you might need more or less than that. nVidia and ATI just give those numbers as a ballpark... and sometimes that ballpark is in a completely different state... but again, I digress.
In short, if you have a basic PC with 1-2 HDDs, 1-2 ODDs, and just an average CPU, then a 200-250 Watt power supply with at least 14 Amps on the 12V rail should be able to run that PC and a low-end video card like the GeForce GT210/420/520/620/720 and Radeon HD3450/4350/5450/6450.
Originally posted by evilkittyI'll admit i did not thing of using the tip cleaning tools with my gun on the pcb, if the solder will not melt i do not see how it would work though
i could not even get the caps out 80% of the time on the board that is what took so long, when i could not get the solder out of the empty hole with the gun i drilled it out
in the event i did get the solder to melt by the time i got the cap half way out it solidified (heat was applied the entire time)
I too will admit that I rarely clean my iron's tips, but that's because I constantly add fresh solder to them and let the old oxidized solder fall of by itself.
The key to making solder stick to your tip is to add fresh solder to it. If fresh solder does not stick to the tip at all, you need to clean the tip with something mildly abrasive. In general, it's best to clean tips in brass shavings, but a wet sponge / paper towel works okay as well. If these don't do it, you might have to use a fine sand paper on the tip - though that could ruin the coating on it in the long term, so I don't recommend it. But once the tip is clean, coat it with fresh solder and let it stay on there. Moreover, don't let the tip overheat before you attempt to coat it with solder - otherwise if it's too hot, the solder won't stick to it. Also, once the solder stays on it for too long and the tip has gotten very hot before, that solder will be oxidized and will hardly stick to anything. Thus, add more fresh solder. In addition to that, always add extra flux to the solder joints you want to work on (be it paste or gel flux). Rosin (R) or Rosin Mildly Activated (RMA) is the type of flux you should be using. DO NOT USE plumber's flux (i.e. fully activated flux) - this stuff is very corrosive and will eat your board traces away.Last edited by momaka; 06-24-2018, 05:09 PM.Leave a comment:
The linear version had it own problems with bad connection on bridge rectifiers or to the transistor or mosfets which ever ones they used
I had one of them that I had to repair a couple times for these types of problems
Yes it is the switching power supply module that has this problem
The controller boards that boot up and showing nothing or shows ( U1 ) are the older controller boards and were meant for the transformer version did not have the time delay for turning on the heater element which is about 5 secondsLast edited by sam_sam_sam; 06-24-2018, 09:59 AM.Leave a comment:
The back light is what fails on the controller boards but what also happens is that the temperature swings are more pronounced when the back light goes bad
That is why I was glad that I found an eBay Seller who is selling them I bought four of them
and they are the newer one ( U3 ) that shows when booting up
Are you wanting one of them if you do PM me and I will send you one
I only have two of them that has done this
I would have to look for the other oneLast edited by sam_sam_sam; 06-24-2018, 09:42 AM.Leave a comment:
btw, what did you do with those faulty controllers?Leave a comment:
that must be the switcher, there are some with a linear psu in them.Leave a comment:
18 volts @ 12 amp but when you get near the 12 amps on start up the power
it does not like see that amperage it will keep restarting the power supply ( it needs 30 seconds to stabilize) then you can get the full power of the power supply
It runs the gun , the air pump and the controller board and a cooling fan if it has oneLast edited by sam_sam_sam; 06-24-2018, 08:51 AM.Leave a comment:
nope, the most i have is 12v, wait i think the zd915 may be 24v, not sure about the amps, the gun is rated for 24v @ 80W so about 3.33ALeave a comment:
i'll look later.
do you have a 24v 5A psu??Leave a comment:
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
by ktmmotocrossI get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
