What are recommended adhesive tapes to use?
  • theojt
    • Jun 2017
    • 48
    I'm digging into some low cost (i.e. broken) TV's for fun. Was wondering what people use for various tapes that are encountered. There seem to be 4 types:
    Thermally conductive (for fastening heatsinks to IC/components)
    Electrically conductive (for ground braids)
    Reinforced, non-conductive tape (general use to secure wires)
    Heat resistant (for reballing primarily) - Kapton tape seems to be the standard
    They seem to be higher quality tape that won't get gummy when exposed to heat, and won't dry out over time.
    Looking for recommended brands/types....TIA!
    master hoarder
    • May 2008
    • 12175
    Re: What are recommended adhesive tapes to use?
    I never replace any of the adhesive tapes. If they don't stick when I try to reuse the original ones, I just remove them and put the monitor back together as is. Never been a problem so far.
    Only exception would be the thermal pads/adhesives, perhaps - those I always keep the original unless they are so bad that they are crumbling apart - then I might try to replace them. But I've never had any like that. On laptops, I replace the NB thermal pads with shims or just add extra thermal paste to the silicone pad if it's gotten too thin.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • triplefour
      LG 75UN8570AUD panel issue fixed with tape.
      by triplefour
      I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
      add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
      07-17-2023, 10:22 PM
    • Katz993
      iMac Display Replacement Adhesive
      by Katz993
      TL;DR: Looking for as-close-to-genuine as possible iMac Thin Panel (2012-2019) Adhesive.
      Long Rant: I run a tech shop that has a specialty in Macs. We've been doing upgrades and repairs on the thin panel iMacs as long as they've been out, and I've always had the issue of being unable to get something close to the OEM Adhesive for the Display Assembly, i.e. a 'two-part' adhesive, extremely thin but durable and can be cut easily with a thin wheel cutter. My replacement adhesive has always been essentially standard thin adhesive. For a long time, the biggest annoyance with this was having...
      03-15-2022, 10:31 AM
    • mitsu2k
      The Real Dangers of conductive glue.
      by mitsu2k
      I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
      Here is an experience I...
      04-16-2023, 06:29 PM
    • RetroComputingGrotto
      IBM LTO 7 Tape Drive - Dust Sensors??
      by RetroComputingGrotto
      I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
      I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
      09-19-2024, 01:54 AM
