Conventional vs arbitrary function generators
  • japlytic
    • Oct 2005
    • 2086
    These days, I recommend arbitrary function (waveform) generators over conventional function generators given arbitrary function generators are easier to use (especially with a waveform display), more flexible, consistent in output and offer better value for money considering that the design (and calibration) of an arbitrary function generator can be less expensive than a conventional function generator (depending on how many waveform types a conventional unit includes) nowdays.
    Many arbitrary function generators include a number of built-in waveforms, some of which are complex e.g. damped sinewave, which can be difficult (and for certain waveforms, impossible) to generate on a conventional function generator.
    I noted that the following calibrations have been dispensed with in arbitrary function generators (most of them have been replaced with software defined functions):
    Typical Calibrations Dispensed With: Distortion, Output Harmonics, Square Wave Needle Suppression, Square Wave Rise/Fall Time, Square Wave Duty Cycle Adjustment, Internal Waveform Modulation (AM/FM etc.), Modulation Low Frequency Suppression, Burst Start/Stop Phase
    Typical Calibrations Still Required: Output Amplifier Offset, Output Amplifier Frequency Compensation, Master Clock, External Waveform Modulation Level
    7
    Conventional
    0%
    2
    Arbitrary
    0%
    3
    No preference
    0%
    2
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Conventional vs arbitrary function generators
    Of course an arbitrary generator can do anything a fixed function generator, problem being, sometimes it's real tough to generate an "arbitrary" function at a high frequency without distortion at low cost...
    So it depends on the situation.
    • japlytic
      • Oct 2005
      • 2086
      Originally posted by eccerr0r
      Sometimes it's real tough to generate an "arbitrary" function at a high frequency without distortion at low cost...
      It depends on what filters you switch in and how good the filters are at a given frequency.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        and depends on how good the filters are for a specific waveform, not to mention adding the filters increases costs.
        • Longbow
          • Jun 2011
          • 623
          I disagree with your entire premise that an AWG is inherently a better type of instrument than a simple AFG. The 2 features are almost exclusive in their practical use, to say the least.
          Obviously it won't make sense to state a distortion figure for a truly arbitrary waveform because there won't be a reference waveform for comparison. Offering specialized built-in waveforms would correctly be referred to as arbitrary functions, whereas a user-defined output would be available in an arbitrary waveform generator.
          Arbitrary waveforms are almost always used in manufacturing testing and burn-in facilities that subject a piece of equipment to a particular testing regimen. It wouldn't make sense to spend the extra bucks on this capability if your needs are simpler. At least, manufacturers justify a higher cost for added features. Last time I checked, the built-in waveforms in an AWG were no different than the built-in waveforms in an AFG.
          The real reason that modern digital units dispense with calibration procedures is that the waveforms themselves, already exist in the unit's ROM, or exist as instructions to a math processor on how to produce them. Calibration procedures that you refer to would only be necessary in analog devices such as the familiar analog sine, square, triangle generators that were the norm until recently.
          I personally would recommend an analog sine, square, triangle generator for 90% of bench uses. Spend the extra money where it is needed such as on a nice scope. The extra features on a DDS generator are cool, but usually unnecessary for typical equipment repair and testing. Just a personal opinion.
          Is it plugged in?
          • llonen
            • Sep 2014
            • 495
            • hampshire
            Conventional for me
              • 31091
              you could probably make an arbitrary one cheap.
              you can get a Nucleo dev board running at 400MHz for $20
              that has usb & ethernet.
              just add a very fast DAC and use dma to stream an uploaded wave-table to the dac from ram.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I don't really have a waveform generator at all :o
                I do have an AVR software based DDS that I hacked up for the heck of it if I need it (using an R-2R ladder for DAC; overclocked to 14.3MHz so it has a maximum of a bit more than 1.5MSPS from the wavetables), and a RF signal generator. With an analog oscilloscope I can easily see the waveforms steps in each of the waveforms on the DDS... Alas I don't have a filter on the output, and I need to finish it by adding offset/amplitude control as well as decreasing the output impedance. Not much you can do with a 90S2313 DDS.
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  Yes I could probably construct an arbitrary one cheap enough I don't make that much use of the conventional one I have to justify the work load.
                  • japlytic
                    • Oct 2005
                    • 2086
                    For new units on eBay, there are more listings for arbitrary units than conventional units.
                      • 31091
                      probably because conventional ones mostly used a special chip that is getting hard to find,
                      microcontrollers on the other hand, are getting cheaper and faster at an amazing rate.
                      • CapLeaker
                        FeelTech / Kuman FY6600 DDS Function Arbitrary Waveform Generator repair
                        by CapLeaker
                        Some Got it as a X-Mas present from wifey. Lasted about 30mins and then it was absolutely dead.
                        Checked the PSU and it was loaded down to next to nothing. Unplugged the main board from the PSU and all is O.k. on the PSU. Ahh! Main board problem!
                        Took the main board out and find a short at T2 (78L05) regulator between the input and GND pin. Took that out including the cap that is next to it and still have a short. I also measured shorts between C53 and C57. Took these out, took the 2 IC's under that heat sink out and still a short! Running out of options...
                        12-25-2018, 04:36 PM
                        Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
                        by sam_sam_sam
                        This is a new item at Electronic GoldMine that has arrived within the last few weeks
                        Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
                        Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
                        https://theelectronicgoldmine.com/products/g28392
                        One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
                        11-24-2024, 01:25 AM
                      • Salvador Pérez
                        Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
                        by Salvador Pérez
                        Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
                        • 0.91V for the GPU
                        • 1.7V for VRAM
                        • 3.3V and 5V rails 1.8V for the BIOS
                        • 0.9V for the CPU and iGPU 1.2V for the RAM
                        However, these two coils are not showing any voltage....
                        03-10-2025, 11:50 AM
                      • Alimash
                        op amp circuit function?
                        by Alimash
                        I am repairing a ups which doesn't turn on ,it has the following ICs:
                        SG3525 used to drive inverter mosfets.
                        couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                        A LM358 and TL074 for control mechanism and of course the uController.
                        The SG3525 is shutting down every time the ups is turned on.
                        I want your help to know the function of LM358 and TL074 in the system.
                        I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                        07-31-2025, 07:45 AM
                      • jason123
                        Agilent 33220A 20 MHz Function Generator
                        by jason123
                        I can't find a forum to discuss "instrumentation Troubleshooting", but PS maybe the closest.
                        So, I'm having an issue with about 13 year old Agilent Function Generator. it works, passes self-test, but it has an annoying "audible" noise, that changes as I change the output frequency setting of the instrument. Prominent around 600 Hz and up (at least that's what my ears are picking up.) I saw on some forms that it could be fan, linear regulator, dried up caps,... I can't seem to find the source of audible noise. Here is what I tried:
                        1. Turn the output off - still...
                        07-01-2025, 08:12 AM
