Motherboard POST card
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Are they any good on newer desktop and laptop motherboards?
    Which ones are good?
    My main objective is to see whether it's a faulty BIOS or something else is faulty.
  • SoporteHR
    • Sep 2018
    • 80
    • Venezuela
    Re: Motherboard POST card
    Hello, receive a warm greeting
    A query, in your experience, it is worth buying those cards for the diagnosis of PCI-e ports.
    I'm starting to repair motherboards, I still have a lot to learn and get tools for my workshop.
    That's why I consult about the usefulness of these cards.
    It happens to me that I have motherboards that turn on and off after a while and that disconcerts me.
    Thank you and I remain attentive to your comments.
      • 31014
      i dont think they will help, for 2 reasons.
      1: the numbers are sent from the bios - no bios, no numbers.
      2: most problems either prevent the board starting or cause randon shit when it's running.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        I have a throughput of motherboards, mostly I work on Macbook products and thus don't have a lot of use for Motherboard post cards, that said a brief look through Ebay shows a substantial number of them and with prices starting at under £5.00 so why not. Your probably better off with a few pieces of test equipment and boardview packages, I have a vast libray of boardview stuff that I would not be without for testing and diagnosis.
        • SoporteHR
          • Sep 2018
          • 80
          • Venezuela
          Hi. sjt and llonen
          Thank you for your response, I see that it is better to invest in something else.
            master hoarder
            • May 2008
            • 12170
            In my experience, POST cards only appear to be -somewhat- useful for -older- desktop motherboards. On newer motherboards, I don't always get a POST code. And on laptops... well the type of POST card I used on laptops required a parallel port and those have been gone from laptops for a long time now. So for laptops... no, not useful.
            In short, POST cards have a very limited use on my bench.
              • 31014
              laptops now post through the modem/wifi socket or an extra connector - seen it on the schematics
              • SoporteHR
                • Sep 2018
                • 80
                • Venezuela
                I know that now there are POST cards that connect to the mini PCI slot where the WIFI card goes. I will review the schemes in more detail.
                Thanks for your coments
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  Well given the current price of a range of POST cards and the plethora of them about, I wold say try one if you think your going to use it. Its not like its going to be a significant investment, that said I have never had a board or Macbook in where one of these would be of the slightest use.
                  • SoporteHR
                    • Sep 2018
                    • 80
                    • Venezuela
                    Thanks, that I wanted to know.
                    Here in Venezuela it is difficult to get currencies $ and locally they have a prohibitive price.
                    Better to invest in something else.
                    • RethoricalCheese
                      • Mar 2013
                      • 1518
                      • Estonia
                      Well, a lot of talk but I don't see any recommendations about the cards. Which cards has anyone tried? Something that works using miniPCIe, m.2 or even DDR3/DDR4 slot (apparently there is a DDR2/DDR3 post card out there but I have no idea if it even works as promised).
                      Only need it for laptops.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3587
                        • slovakia
                        have abou 5 types of post cards for laptop but nearly non of them will help. works only on older laptops /ddr2/ and codes they give will not help
                        • Conste
                          • Oct 2018
                          • 235
                          I purchased a mini PCI-E card and it doesn't work in any laptop I have here to repair. Some DELL Inspirion N7110 didn't even boot with the card inserted.
                          Some Asus just shows 0 all the time
