ShopJimmy LED Strip Rework Station - Single LED Replacement Tool
  • R_J
    • Jun 2012
    • 9588
    Re: ShopJimmy LED Strip Rework Station - Single LED Replacement Tool
    Is this it? https://www.aliexpress.com/item/PTC-...27023b32CUMREi
    • diif
      • Feb 2014
      • 6978
      • England
      Originally posted by WhiteWolfHellas
      Thanks for the reply, but the link is not working.
      Glad to hear no comebacks even after greatly heating up the new led. Do you lower the backlight after the repair in order for the leds to last longer?
      Apologies, I shortened all the tracking info from the link and trimmed too much.
      https://www.aliexpress.com/item/1pc-...974173898.html
      I remove the LED with the heater but depending on how much solder is left I then remove all the leaded solder and replace with lead free.
      When attaching a new LED it's staying well within reflow temperature parameters.
      Yes I turn down the back light.
      • WhiteWolfHellas
        • Jun 2019
        • 95
        • Greece
        Do you replace the shorted LEDs, or do you replace every LED in the strip, even the good ones with new? Plus, isn't in more convinient to use liquid solder?
        • diif
          • Feb 2014
          • 6978
          • England
          Just the damaged ones usually.
          The LED strip is resting on a hotplate, the solder is liquid.
          • WhiteWolfHellas
            • Jun 2019
            • 95
            • Greece
            Just the damaged ones only? Strange that you haven't got returns because the old ones tend to die shortly after. I have had returns by replacing just the damaged ones so I stopped using this repair method.
            • diif
              • Feb 2014
              • 6978
              • England
              #26
              Not really, after repairing the failed ones I run the backlights at 100% for 24 hours. Any further failures are replaced before they are turned down.
              • WhiteWolfHellas
                • Jun 2019
                • 95
                • Greece
                #27
                Is it guaranteed that with this method (replacing just the dead ones and leaving the TV on at 100% backlight for 24 hours) the about to die old ones will die for sure? I mean what if you stress them and they die a week down the line? You'll have to repeat the proccess.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  I warranty my work but nothing is every guaranteed, even new can fail.
                  If I stress them and they die in a week I replace them, but I haven't had to yet.
                  • WhiteWolfHellas
                    • Jun 2019
                    • 95
                    • Greece
                    #29
                    So, for example in a 10 led strips TV, only 3 leds are burned out. You just replace the 3 leds, leave the TV on at 100% backlight for 24 hours and if there are more to die, they die, you replace them and leave the TV on for another 24 hours? If it still works, you assemble the TV and call it a day?
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #30
                      I do use a bench power supply for my testing so perhaps they are failing then rather than with the TV powering then. I haven't had any failures when testing for 24 hours
                        https://www.aliexpress.com/item/32974173898.html
                        item #32974173898
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #32
                          Originally posted by budm
                          They work better if the screws and feet are mounted the other way round so they raise the plate off the worktop and the narrow middle piece is used for the heat rather than the larger size.
                          I have a thermocouple jammed inside to get an idea of the temperature.
                          I intent do connect it to a PID and a relay for slightly better control but it doesn't burn FR4 unless it's left on too long.
                            They sure have lots of 230V version, 120V seems to be hard to come by on Ali.
                              • Jul 2011
                              • 6064
                              Here is a 24 volt version of it
                              It not quite the same size but it should work
                              I ordered 10 of them
                              http://s.aliexpress.com/uie6nue2
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #35
                                Is it because they are not affected by the voltage difference ? I tried controlling my PTC with a variac but it still got the same temperature.
                                Yes can confirm, setting the voltage to 120V with my variac and the heater still gets to temperature.
                                Yes, I looked at those, then wondered how I would mount them.
                                  • 31197
                                  sale starts in 2 days - $4!!
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    #37
                                    Originally posted by stj
                                    It was £3.50 at the beginning of the week. Nothing like putting the price up just before a sale !
                                      • 31197
                                      i said $, not £
                                        Thanks for testing it out at 120VAC, I will order a couple to play with.
                                        • shahnld
                                          wds-580 rework station issue
                                          by shahnld
                                          Good day.
                                          i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                          Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                          kind regards...
                                          03-28-2024, 01:14 PM
                                        • minimania
                                          Need Schematic for jbc am6800 rework station
                                          by minimania
                                          hi all im looking for a Schematic for jbc am6800 rework station
                                          mine has stopped working fully
                                          it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                                          now it wont turn on at all...
                                          01-28-2025, 03:44 PM
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • shahnld
                                          Seamark ZM-R6200 Rework station
                                          by shahnld
                                          Good day Experts.
                                          I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                                          Kind regards
                                          01-24-2024, 10:55 AM
                                        • rex98
                                          HP DMI Tool
                                          by rex98
                                          HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                          DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                          The DMI Tool given here are for personal use only.
                                          DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                          You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                          from it, and that you please credit the author...
                                          07-02-2025, 05:51 AM
