CH341A and W25Q128BV
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    I have a dead msi bord that needs to be flashed, board has spi connector below the W25Q128BV wson and I'm looking to buy a CH341A but I'm unsure if I should buy the simplest or the latest version. Latest version has the isp connector that I can hook up to the spi connector on mb.
    Should the mb be powered by atx when flashing or am I way off ?
    • 30985
    Re: CH341A and W25Q128BV
    the cheap black programmer can do that,
    but make sure that connector in the foto is actually linked to the flash and not for something else.
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      It's hooked up to the W25Q128BV alright, every pin but wson pin3 write protect IO2 so I guess perhaps the mb is setup for standard and dual spi instructions.
        • 30985
        no issues then.
        i happen to have a black programmer in my hand.
        the connector pinout is this:
        1 - CLK
        2 - CS
        3 - MOSI (DI)
        4 - MISO (DO)
        5 - GND
        6 - 3V3
        7 - 5V
        so you just need the first 5 pins - power the motherboard before you flash it.
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          Ahh thanks, why should I power the mb before I flash it ?
          Should the atx psu be connected or turned on before I flash it ?
            • 30985
            connected and turned on.
            the flasher cant power the chip because it will be connected to a lot of other parts on the mobo.
            • Gabriel
              • Jan 2010
              • 620
              • Norway
              Had som spare time today to have a look at the mb - mb would not turn on and stay on. It kept restarting every 2-3 seconds so impossible to flash chip.
              I removed the 0 ohm jumper and gave bios chip 3.3v from programmer, used sw 1.18 without problems.
              Mb now working as it should
              • mockingbird
                • Dec 2008
                • 5484
                Congratulations...
                Had an SMD chip like that on an old ChuWi Vi8 tablet. For some reason, updating the video driver to Intel's latest overwrote the flash and bricked it.
                Luckily, he included a blank adapter board where you could solder SMD chips on to, so flashing it took a little figuring out but ultimately it was a success. Dumping the chip confirmed that it was different from the BIOS that ChuWi sent.
                • Tomylee
                  No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                  by Tomylee
                  Sorry for the person who’s going to read all this !
                  I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                  While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                  During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                  07-11-2025, 11:52 AM
                • 5mall5nail5
                  Help identifying connector for ASUS 4090 Strix RGB LED connector
                  by 5mall5nail5
                  Hi All -
                  I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                  Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                  05-04-2025, 07:47 AM
                • md500
                  [Question] Ch341a and 5v to 3.3v with logic converter
                  by md500
                  zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
                  Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
                  What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
                  I can't buy the ch341a 1.6v that has...
                  05-24-2024, 06:51 PM
                • bussincaps
                  MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                  by bussincaps
                  Hello All,
                  tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                  Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                  eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                  Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                  I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                  08-03-2023, 12:57 PM
                • michhak
                  Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                  by michhak
                  Hi guys,
                  i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                  It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                  11-17-2021, 05:45 AM
