Cheap P6100 probes = junk?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Cheap P6100 probes = junk?
    I chanced upon getting an official Tek P6120 x10 probe. Alas it's only a 60MHz probe, but I can assume that Tek really means 60MHz. I tried hooking up a P6100 probe to Ch.1 and a P6120 to Ch.2 and tried comparing the two...
    Unfortunately no fast edge to check rise time...
    Alas other than mucking with the compensation a bit to match my scope... can't really tell much difference using the calibrator output (not unexpected...). The calibrator output doesn't really have a fast rise/fall time.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      ALLRIGHT... I built an avalanche pulser (breakdown testing of a 2N3904 and 150V supply, 20pf cap discharge) on a breadboard, and tried measuring rise time with the cheap china probes... On my Tek 2465, I got... 1.96ns risetime. This is scope + probe + breadboard...
      My 20MHz scope... Being non-digital and 100ns/div is the fastest sweep, was tough to tell. I estimate around 20ns rise time, maybe less.
      I also have some Tek P6120s which are rated 60MHz probes.
      Rise time = 1.88ns on the Tek 2465...
      What the...
      Well at least the china P6100 probes are almost as good as the P6120's.
        • 31197
        it's possible the tek probes can go over-rating,
        and the chinese meet spec.
        i'v seen people on EEVblog using 100MHz scopes to view upt 300MHz signals - although not perfectly!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Well if the probe isn't rated for 300 and you run it at 300, it just means it's attenuated. Trouble is, indeed, it's a bit iffy to use them because now the 300MHz component is attenuated but the 100MHz component isn't, so your waveform looks a bit distorted from reality (!)
          But it looks like in Tek's world with their screwy formula,
          P6100 = 1.96ns => 180MHz
          P6120 = 1.88ns => 194MHz (!)
          20MHz scope = 20ns => 17.5MHz ... At 17ns it would be 20.6MHz, but in any case the scope is limiting bandwidth, not the probe.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Hmm... and my third scope (DSO), using its onboard rise time measurement, says ~1.6ns rise with the cheap china probe (!). However this DSO is using multisampling to get a waveform (Tektronix 2440: 300MHz frontend, 500MS/sec backend). Ah... the conveniences of a DSO...
            All in all I guess other than the possible crappy construction issues that will cause the probe to disintegrate on you, the P6100 does indeed meet 100MHz spec. Thumbs up. I do wonder if there are "clones of clones" of these probes (seems like there are multiple versions) - and whether they are up to snuff.
            Hmm. I may have to build the pulser into a self contained unit, hopefully to reduce parasitic inductance to stop ringing and to test other things later. Though I will have to figure out how to squeeze in a power supply for it...
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Pictures!
              My Tek 2440, Tek 2465, and 20MHz VuData scope output from the pulser and the cheap china probe (P6100)
              I don't know why the 2440 rings so much worse than the other two...Something weird going on. Termination was off on this run but didn't help much with it on.
                HP Pavilion Pavilion p6103uk Pavilion p6100 E5200 Specification for Upgrade or Repair
                This specification for the HP Pavilion Pavilion p6103uk can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6103uk boardview and Pavilion Pavilion p6103uk schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 03:36 PM
                HP Pavilion p6126uk Pavilion p6100 9650 Specification for Upgrade or Repair
                This specification for the HP Pavilion p6126uk can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion p6126uk boardview and Pavilion p6126uk schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
              • corrize
                Small and robust multimeter probes
                by corrize
                Hello, I search a new probes for measuring pin of qfn and other very small stuffs. I bought the AE basics ones, but they are no longer sharp. Metal is bad. Do you have a stonger ones ?
                05-13-2023, 02:36 PM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • SolomonMan
                Vintage BK Precision 1403 Oscilloscope....
                by SolomonMan
                All,
                Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                12-03-2023, 10:39 PM
