How NOT to replace a water heater!!!
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    https://www.youtube.com/watch?v=2prbMRm8fkg
    Isn't that smoke pipe nice??? Not enough rise with the new unit(taller) and there's a patched hole in the chimney! Should be entering chimney thru the hole directly above the new heater, dumbass...
    More labor and material to patch chimney and snake that flue around into the wye after the furnace...
    Just because you can "throw pipes together" doesn't mean ya should- Steve Lav oughta "swat" that hack for being "stuck on stupid."
    https://www.youtube.com/watch?v=hsjW90PlYoc
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: How NOT to replace a water heater!!!
    Isn't flex code in most jurisdictions?
    Follow the white rabbit.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8696
      You can thank government efficiency standards for the tanks being larger than before... the status quo of all tanks being the same size was broken.
      Not sure what the best solution is. Even a newer house without a brick chimney would run into the same issue.
      It seems the residential codebook indicates the flue pipe must rise a quarter inch for every foot. This seems very low it's less than 2° (!) I'm surprised that even works...
      I had a new water heater installed recently and fortunately the vent flue was low enough but even it I was a bit surprised. It rises about a foot for that 5 ft length for a 11° angle...
      • edugimeno
        Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
        by edugimeno
        Hi!!
        Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
        I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
        At a certain point, moving stuff around, I put all wires back in place and...
        03-24-2024, 02:31 PM
        Tankless hot water heater controller board not powering up when power is applied
        I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
        I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
        However I would like to know if I could figure what happened to this controller board if possible
        Tomorrow I will take some better pictures of both side of both boards
        The...
        12-09-2022, 09:14 PM
      • nop
        Busted tankless electric water heater control board
        by nop
        Hi. I have an old Bosch/Powerstar AE125 water heater in my cabin whose control board died for the nth time. This time around, I figured I'd try to diagnose and repair it. At the end of the board's life its power indicator LED will quickly cycle on and off as water passes through the heater, rather than remaining steadily on as it normally would, and water at the tap remains cold. Slightly increasing pressure in the system by closing the outlet valve seems to delay the inevitable for a little while.
        Here's all the info I found from Bosch regarding troubleshooting the board:
        04-27-2022, 09:57 AM
      • madan1
        Diesel heater emergency power supply / poor man's UPS
        by madan1
        Hello everyone.
        Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
        12-18-2022, 08:05 PM
        Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
        I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
        I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
        12-16-2023, 08:39 PM
