Bench PSU recommendations
  • newtothis
    • Mar 2013
    • 1556
    • england
    Right for some time now I gave up on tracing shorts on CCTs that I cannot get schems for... Time for the current + freeze spray method and take another look at some of these boards I have.
    Recommendations on a good make/model suited for the Job?
    As usual price doesn't matter
    Cheers
    • 31198
    Re: Bench PSU recommendations
    i dont have one, but i like the look of the rigol dp832
    http://www.rigol.eu/products/dc-powe...s/dp800/dp832/
    https://www.youtube.com/watch?v=IaWgF1SORkk
    • gearhead63
      • Jul 2014
      • 14
      I myself don't have any "new" bench supplies. But I do have an old Lambda LH125FM, an HP6202B,an HP6205B,and an HP6212B. These are fairly cheap, reliable and most important, REPAIRABLE!
        • 31198
        anything new will have a microcontroller in it, so a warranty is your friend.
        • switcher
          • Jul 2013
          I'd look on Ebay for a used Thurlby, Farnell, or Weir.
          Good, solid British kit, and very repairable.
            • 31198
            only if they dont need repair.
            Thurlby-Thandar aka Sinclair make terible schematics.
            Farnell ones are just hellish to find - if they even exist.
            never heard of Weir before.
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • Eniaro
              Bench test a series X
              by Eniaro
              How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
              06-17-2025, 01:46 PM
            • rabsonnjala
              LENOVO IDEAPAD 100 works only on bench power supply
              by rabsonnjala
              Hie I have a Lenovo laptop
              Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
              it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
              below are my readings
              with the original charger only
              JBATT1
              PIN1 0.22V
              PIN2 0.22V
              PIN3 0.45V
              PIN4 0.45V
              PIN5 O.43V
              PIN6 0V
              PIN7 GND
              PIN8...
              11-20-2021, 08:32 AM
            • Geeker007
              Friend messed up my laptop motherboard while working on my bench
              by Geeker007
              Hi All,
              So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
              So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
              I have not tried putting...
              06-16-2025, 01:40 PM
            • Crystaleyes
              Bench PSU question
              by Crystaleyes
              Hi all.
              Looking for some help regarding the workings of this unit.
              Some time ago I picked up a digital bench power supply from the local flea market here in Rio. It's a 'Sincler SPS 3015/D' which I imagine is 30V, 1.5A 'Digital'.
              Even though it would turn on and show a display, it wasn't working, and no matter how hard I have looked, I've found no reference let alone any kind of schematic. I imagine it is from the late 70's or early 80's? I can only assume that all the components are to the original specs although it had clearly had prior work done so it 'is' possible...
              11-12-2024, 05:05 AM
