Got a soldering station with hot air blower?
  • japlytic
    • Oct 2005
    • 2086
    If you do (and it has a flow rate and temperature adjustment), you can use the hot air blower to test suspect components for heat-related problems (such as linear regulators which may be dropping out when warm), provided that the heat setting is not excessive.
    07-01-2024, 06:34 AM
  • chth96
    What soldering station should I purchase for 900M-TJ-I tip?
    by chth96
    hello.
    A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
    https://ko.aliexpress.com/item/4001275635593.html
    Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
    Any reply would be appreciated.
    11-24-2023, 05:08 PM
  • caprider
    Recommendations of quality soldering station and (separate) hot air station
    by caprider
    Hey,
    I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
    I now have a TS100 and some soldering irons and looking for some better tools.
    1. Soldering station, budget around 200-240€
    JBC BT-2BWA seems to be a good product in the budget.
    2. Hot air station, budget around 200€
    Up to now I've found ATTEN ST-862D to be a good option....
    01-15-2022, 02:05 AM
  • mkbehbeh
    KSGER C245 Soldering station PSU 220V only?
    by mkbehbeh
    I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
    I am...
    04-17-2023, 03:11 PM
  • Peter_1402
    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
    by Peter_1402
    Hi Everyone,
    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
    1. Soldering iron works great
    2. There is a burnt mark on the hot air gun handle.
    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
    Reed switch tested ok with a magnet.
    From the above test, I can conclude...
    07-12-2025, 11:50 AM
