ESR meter upgrades
This is a sticky topic.
    Re: ESR meter upgrades
    here is your foto of using an LM4040 inplace of the TL431
      stj ive noticed the last few months some more of these testers have come out i wouldnt mind a colour screen version 16 mhz which one are you recomending at the minute
        there is only one colour unit as a kit / with software.
        there are 2 others sold in cases that look interesting - wait a while.
          Cheers will do im in no rush.
            Do you know if an SCR should be possible to read on the transistor tester?
            Specifically a S2514NH. (Attached datasheet).
            It shows up just as a 15ohm resistor. (I am suspecting something is wrong with the SCR).
              no idea, it may depend on gate current.
              i cant tell you that low gate current triacs can be tested - because i tried one yesterday.
                That definitely sounds suspect. Check it with your multimeter. It's essentially like a BJT with an extra diode junction on the Collector.
                See SCR Construction @ Wikipedia: https://en.wikipedia.org/wiki/Silico...r#Construction
                That said, you should get an open-circuit between Anode and Cathode terminals (A and K), and a diode Vf between Gate (G) and Cathode (K).
                Good point in asking if the TT can check this component. IIRC, I remember a picture of one showing it testing a TRIAC. Don't remember about SCR, though. I don't think I have any SCRs in my junk box so can't check.
                  the test current is very limited.
                    Thanks Momaka!
                    -I get 7MΩ
                    -I get 0.036
                    I asked on eevblog too and got this reply:
                    This device is capable of recognizing Thyristors IF the gate current is <~ 5-6mA.
                    Your SCR requires minimum 20mA so cannot be recognized. Your SCR could well be OK.
                    Graham
                    I reckon it's dead, could this work as a replacement?
                    Thing sits in an electric fence controller...
                    https://www.elfa.se/en/thyristor-to-...00r/p/17201058
                    I've seen one Chinese version with a booster circuit, I assume that would then have the possibility to measure my SCR?
                      the booster is voltage, not current - it's for zener diodes.
                        -I get 0.036
                        That looks like a Gate to Cathode short-circuit.
                        Yup, I think it's bad. I had two big RCA 1884 SCRs from a very old HP DC power supply that were blown the same way. Also, yesterday I just pulled a TRIAC from a home food processor. Was O/C between A and K terminals with a short-circuit between the input A terminal and G . Thankfully, the IC and driving circuitry was undamaged.
                        Well, I am no expert on SCRs and TRIACs, but that looks about right. You got the same current and voltage ratings. The gate current on your replacement part is a little more sensitive, but I think that's a good thing, because then the controller should be able to drive it more easily (kind of like a MOSGET with a lower gate charge/capacitance).
                        Yes, I think I remember readings something like that too.
                        Then again, all you need to test a Zener diode is a breadboard, a few resistors, and a power supply with a high enough voltage and current.
                          about swapping triacs.
                          one thing i learned the hard way - make sure you know if the original and replacement have an isolated tab or one linked to the center pin.
                          unless you want a live heatsink!!
                            A few days ago my Tester DIY Kit arrived. But without any documentation. Only the PCB and the parts.
                            My question is if someone with the same tester can take a picture of it without the LCD installed? That would help a lot.
                            And i want to ask if it is possible to protect the tester against a charged capacitor. Or better protect the tester in case i forget to discharged a capacitor.
                            That are the parts i got from ebay (the 16Mhz crystal is still in transit but the LM4040 is already here)
                              i dont know why a foto would help? all the part values are marked.
                                The assembly doc and manual are attached here.
                                Perhaps reading this thread will help you further:
                                http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/2400/
                                  updates.
                                  because i'm probably moving soon due to gentrification and all my shit will be in storage!
                                    updates.
                                    Sorry to hear that stj . I absolutely hate moving myself. I hope you don't get dealt a bad card with that. Have you found a new place yet? (perhaps keep us updated in VIP.)
                                      no idea about anything.
                                        Thanks for the update, finally put in a 16Mhz crystal to test it, worked fine
                                        Got any firmware built for 20Mhz too?
                                          no, it cant do it because the delays are carefully tuned for each crystal speed.
