Osciliscope newbie
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Osciliscope newbie
    Hello all
    I am woorking on repairing pc many years and in the last year I am trying to repair laptop motherboards.
    Many told me that I need an osciloscope for repairing laptop motherboars and other electronic as well.
    Can somene help me to choose a cheap one and guide me how to start working with an osciloscope (book, webpage ,etc)
    I worked with osciloscopes in school but I wasn't paying too much attention
    So I need a newbie guide.
    thanks in advance
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Re: Osciliscope newbie
    A friend told me that the oscilloscope must have component tester but he doesnt know any model.
    What is the best digital or analogue?
    • Stefan Payne
      • 1267
      eevblog??
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        I am sure someone will help you soon. Here is a link to a tread with a similar question. You might want to take a look. https://www.badcaps.net/forum/showthread.php?t=48020
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Sometimes I wonder: what do you use a scope for, when repairing modern equipment. I think for the most part you're looking at power supply issues because data signals transition too fast for people to see (and tends to be meaningless by itself). Since power supplies rarely run at several MHz (due to gate and circuit loss at high frequencies, along with RFI) even older low frequency scopes are sufficient...
          Or has someone found some great use for scopes on board repair? Maybe a logic analyzer if used properly is more useful?
          I'd guess 'scopes are more for people who want to do analog/radio work. Or if you want to reverse engineer something.
            • 31196
            if you dont know what to use one for then you dont need one.
            besides, they arent toys - atleast usefull ones arent, you can expect to pay several hundred for a new one.
            even an ancient scope is going to be expensive if it's fast enough to be usefull - like 100Mhz+
            • tranquility
              newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
              by tranquility
              hello, i am very new to laptop repair and generell electronics
              i have a HP Spectre X360 Convertible 13 - ap0016ng
              motherboard number DA0X36MBAE0 REV E
              massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
              found a shorted capacitor. removed it and the short is gone.
              i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
              in this area another capacitor was shortet.
              12-06-2024, 04:12 AM
            • UL161
              Need Help Identifying Parts on a crossover and a few other newbie questions
              by UL161
              Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
              1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
              2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
              09-29-2024, 03:17 PM
            • cloghin
              newbie questions
              by cloghin
              Apologies if I am asking the wrong questions , but not sure how else to start:
              I have an A2251 / 820-01949 Mac book pro with no power, 20 v on USBC meter and 0.05 Amps. Following this link ( below)
              * Do I need to remove the board from case so I can access its other side ? The link calls for measuring PP3v3_S5 ( I suppose this is in diode mode with positive probe on ground) , but I don't know how to do that without removing the board from case.
              * I have the FlexBV board , are the values displayed in volts diode mode only ? Because my etekcity multimeter shows...
              09-26-2024, 11:48 AM
            • Cappy Oligan
              Newbie about to dive in with the leads. Safety advice please.
              by Cappy Oligan
              I'm new to electronic repair. Trying to troubleshoot a Dell monitor that only has an AC port for power. I'm concerned about safety and not getting shocked. Should I order an isolation transformer and plug in the monitor into that and proceed with testing the board inside? Or should I get a DC power supply and limit the amps and connect the voltage to a pin somewhere inside where 19V DC is first expected? Or both? Thanks.
              08-30-2024, 05:40 PM
            • Jofo
              eVGA GTX 970 - newbie fixing
              by Jofo
              I am a newbie and this is my first repair attempt on eVGA GTX 970 that I bought from one guy. He said that his power supply died and took the graphics card with it and smelled smoke from the card too. When I took the card apart, one of the high-side MOSFETs was obviously damaged and there was a short on one of the PCIe connectors.
              The situation now is as follows:
              - The choke was already damaged when I disassembled the card
              - I've desoldered the high-side MOSFET "H" that was damaged, short gone...
              09-29-2022, 03:22 AM
