What boards do not have lead-free solder
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 662
    • samsara
    Finished perusing this article Rollback the Lead-Free Initiative
    Can one determine if a board has lead-free solder by a visual inspection?
    When did computer motherboards and GPUs start to be manufactured with lead-free solder?
    i.e., what were the first series of AMD motherboards and GPUs that used lead-free solder?
    I want to keep as far away from lead free soldering as possible
    • 31283
    Re: What boards do not have lead-free solder
    company's can use lead free at any time they want,
    but they had no choice after 2006.
    so pre-2006 it was up to the company's.
    there is nothing wrong with lead-free btw, it gets a bad rap because of poor choice of flux, bad soldering equipment, and a few company's selling products with inadequate cooling (mainly microsoft)
    btw, if a board has a sybmbol that looks like the letters Pb with a cross or slash through them it is lead-free.
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 662
      • samsara
      It's hard to find info on this.
      "VIA announced today that their AS-1210 motherboard will be the world's first lead-free motherboard." - From an article dated April 2004
      And from the Asus website: "ASUS produced the world's first lead-free and Halogen – free motherboard" + "2004: Launched lead-free motherboards"
      So who produced the first Pb-free motherboard? VIA or ASUS?
      And when?
      Can't find any info for Gigabyte.
      Going by the user manual copyright (if that's anything to go by), it seems that socket A manufacture is around 2002-2003,
      and socket 754 and 939 is in the vicinity of 2004 - 2006
      But when did Gigabyte make the switch?
      Are all of these 754 and 939 boards Pb-free, or did they make the switch sometime in between?
      Also, isn't it best to determine the type of solder on the board before using an iron on it?
      Because i read that it can lead to contamination of the tip.
        • 31283
        firstly it's worth pointing out that china has it's own lead-free rules that are more strict than RoHS.
        as for soldering, what do you mean by contamination?
        you can clean the tip.
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 662
          • samsara
          Ok that's a consideration
          So any board that was manufactured prior to 2006, that does not meet the European RoHS specification, may, or may, not be Pb-free?
          And, in that case, the only way to find out is by checking the temp that it melts at.
          It seems that the European RoHS predates the Chinese RoHS which began to be phased in in 2007
          No Mention of EU or China RoHS, in the Mobo Documentation, means that there's a good chance that solder job is Sn/Pb
            • 31283
            well lead costs more than tin.
            and tin/copper solder works fine with the correct temperatures and flux.
            so a lot of company's switched to leadfree as soon as the flux was ready.
            flux was the big holdup that took years to solve - it's still the thing that makes a big difference between solder brands.
            you cant just use rosin desolved in IPA on unleaded solder - it burns and makes a mess.
              • 31283
              btw, contary to what that guy in the link says, it's easy to detect lead in solder.
              there are chemical test-sticks.
              you wipe the solder with them and if there is any lead they change colour.
              they are used by process inspectors.
              • mariushm
                • May 2011
                • 3799
                It's not quite that simple.
                You have to be careful when you read the wording of such press releases. One company may mean that they didn't use leaded solder when soldering all the components to the PCB... but they don't say if all the chips they placed on the boards had the leads tinned with lead free solder or some solder with lead in it.
                Some ICs could have solder with lead inside, depending on the package.
                Also, under RoHS there are plenty of exceptions where you can use solder with lead.
                I don't see why. Lead free soldering is just a bit more difficult, due to the higher temperatures required to melt the solder. A small negative for lead free soldering would also be the fluxes which have to be just a bit more active, powerful, because they have to do their job in much shorter time, before heat from soldering iron burns them out.
                As long as there's some ventilation in the room and you use a good soldering iron, there's nothing wrong with lead free soldering.
                If you're concerned about using soldering iron tips advertised as lead free on boards that aren't rohs, don't be. It's not a big deal, the contamination of a lead free board with leaded solder during repairs and so on is acceptable and doesn't really cause problems in reliability (or other ways)
                So again, what's the real reason you're asking these questions?
                  • 31283
                  can be minimised by simply wiping the tip with a brass-wool cleaner and a wet sponge between jobs.
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    If you want to be a purist about it then use different tips and cleaners, one set for each. But I see no reason for much concern about it.
                    • socketa
                      Asbelowsoabove
                      • Jun 2014
                      • 662
                      • samsara
                      "what's the real reason you're asking these questions?"
                      because i am from the pleiades and crashed here on this god-forsaken planet, and i need to fix the circuitry inside my spaceship so that i get the heck out of here.
                      slightly more seriously,
                      after reading the threads in the forum, it is quite obvious that Pb-free is the most preferred method by most members, and there would have to be a a good reason for that
                      and from checking out other webpages:
                      higher temp is bound to lead to shorter tip life
                      the stuff doesn't flow as well
                      more prone to fracture
                      produces 250% more toxic airborne particles
                      the component is subject to higher temp
                      the growth of tin whiskers
                      etc...
                      So if i have a choice between two boards, it makes sense to choose the lead-free one.
                        • 31283
                        Originally posted by socketa
                        1: higher temp is bound to lead to shorter tip life
                        2: the stuff doesn't flow as well
                        3: more prone to fracture
                        4: produces 250% more toxic airborne particles
                        5: the component is subject to higher temp
                        6: the growth of tin whiskers
                        1 - no.
                        2 - wrong again - just need the right flux in the solder.
                        3 - fracture over tearing, but stronger than lead before it cracks.
                        4 - that's down to the flux, i'v seen some pretty nasty fluxes in leaded solder in the past.
                        5 - maybe - different people solder at different temperatures, i solder lead-free at 310 - i'v seen forum members use 350 on leaded solder sometimes.
                        6 - never seen it, i suspect you need specific enviromental conditions.
                        the wiskers cant actually "grow" btw, that would require extra tin - it must be some form of migration effect.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Originally posted by stj
                          1 - no.
                          My thoughts on your points:
                          1. Agreed.
                          2. Mostly agree. (I haven't used lead-free solder much, so not experienced with it as much as I could be)
                          3. Mostly agree. It does take longer to cool too (needs higher temps in the first place), so keep that in mind while soldering.
                          4. Agreed! Some smell really strongly. Some also leave a residue that is conductive, and some leave a residue that is hard to remove.
                          5. Partly agree. I've never had any issues with heating parts up for long times. I obviously don't heat electrolytic caps up for long, you know why LOL. But that's not to say that heating parts up for a long time could damage them.
                          6. Partly agree. Most tin whiskers apparently are very thin, you likely won't be able to see them with the naked eye. Now, if there are a LOT of them, you can see the "fuzz" then. Yes I've heard that for some reason, electroplated tin can cause tin whiskers. Not sure why, and I'm not 100% sure if that is true.
                          Just my 2 cents.
                          -Ben
                          Muh-soggy-knee
                            • 31283
                            electroplated tin will leave a layer of tin sulphate on the surface when you remove the current,
                            the item really should be washed and polished afterwards - i bet they arent!
                            the same applies to any other electroplating.
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              etc...
                              I'm sorry but something isn't making sense to me here. You're pointing out all the negatives of using lead-free while saying it's better to use lead-free. ?: |
                                • 31283
                                shhhhhh.......
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8707
                                  I thought tin was around $7/lb, lead around $0.80/lb today: tin is much more expensive.
                                  60 Sn/40 Pb was made because eutectic 63Sn/37Pb had more tin and thus more expensive.
                                  Lead was added mostly to prevent whiskering, plus lower melting point and well defined melting point makes it a lot easier to work with. It also made solder cheaper, to boot! Three birds with one stone!
                                  • acedogblast
                                    by acedogblast
                                    11-02-2024, 05:13 PM
                                  • ugamazing
                                    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                    by ugamazing
                                    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                    12-17-2024, 07:05 PM
                                  • corrize
                                    Best way to solder LVDS connector for beginner (and qfn) ?
                                    by corrize
                                    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                    See the test :
                                    https://youtu.be/bNAzC-EvqHs?t=1767
                                    With hot air from bellow the board, that's...
                                    03-09-2023, 02:57 AM
                                  • AJ847.63e
                                    What technologies are required for modern motherboards (6thgen - current) to post?
                                    by AJ847.63e
                                    Hi All,
                                    Need a bit of assistance digging up some information on current technology support required for modern motherboards to post? By modern let's say 6th gen skylake to current intel and all of the Ryzen series. You would think this would be on the ARK product page, but nope. Besides saying dedicated graphics required it doesn't really tell you squat.
                                    Reason I ask is I've ran into this a few times now (first on 6th gen SkyLake and now on 12th gen AlderLake) where if I use an intel F SKU CPU multiple different boards refuse to post with multiple different graphics...
                                    11-09-2023, 07:23 PM
                                  • ugamazing
                                    Apple M1 Boards & Exclamatory Error?
                                    by ugamazing
                                    We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
                                    Has anyone else run into this...
                                    02-20-2025, 09:24 AM
