Need advice - Which laboratory power supply to buy?
  • scokljat
    • May 2012
    • 275
    • Croatia
    I'm about to buy 2 x 0-30V 5A lab power supply.
    After tour around local tech shops I narrowed selection on two models:
    Matrix MPS-3005LK-3 (222$)
    http://www.szmatrix.com/en/product_show.asp?id=103
    or
    McPower DIGI 302-05 (252$)
    http://www.zeitech.de/McPower-Digi-3...Anzeige-30V-5A
    Matrix looks better, has big alu heat sink + two fans, voltage can be adjusted very fine because knob make 3 full circles from 0-30V, it's 30$ cheaper than Mc Power. Manufacturer (Matrix) has good webpage and company produce professional lab equipment.
    Mc Power does not have visible alu heat sink, it has two fans which spin variable as unit heats up. At start it makes it more silent than Matrix (fixed fan speed) but I didn't test it under load to check how silent fans are when unit heats up. Manufacturer (McPower) looks generic - no name. Didn't find official webpage, unit is mentioned only on webshops.
    Both units have an extra 5V/3A fixed channel.
    Currently, model from Matrix looks more solid to me.
    Which one should I buy? Take a look at attached pics and specs. Any suggestion is more than welcome...
    Thanks,
    Best regards,
    Suad
    • 31198
    Re: Need advice - Which laboratory power supply to buy?
    or this one.
    http://www.rigol.com/prodserv/238/
    • redwire
      • 3912
      Both of them look like vanilla linear PSU's from China. The Matrix looks better constructed, like GW Instek. They can be touchy to dial in an exact voltage or current.
      Newer bench PSU's like the Rigol use switching power supplies and have neat features like programmable pulse outputs, high res panel meter, keypad, LAN and USB etc.
      It depends what kind of work you are doing. I really hate noisy fans running all the time so I have big, heavy and silent linear power supplies on my bench.
        • 31198
        the Rigol actually uses a Linear regulator and a big toroid transformer.
        there is a teardown video at EEVblog
        https://www.youtube.com/watch?v=s4rV20ulsm0
        • redwire
          • 3912
          The Rigol DP832 is selling for $450-500 USD, and I had to chuckle because the teardown shows no protection diodes, and Dave at EEVblog found a transistor running at 90°C and overvoltage spike during power up, in 2013.
          http://www.eevblog.com/2013/08/30/ee...investigation/ Rigol has since fixed the bugs.
          I don't mind analog linear PSU's...
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • repair-it
            Need advice testing a samsung power supply board with scope
            by repair-it
            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
            07-12-2025, 11:00 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
