Extending the life of your hot air blower
  • japlytic
    • Oct 2005
    • 2086
    Before turning off power at the master switch of your hot air blower (which can also have a soldering station function), turn off the hot air blower function at its own switch (typically Standby); the blower pump (with heater off) will continue to operate until the unit has cooled down adequately; when the pump stops operating, it is safe to turn off power at the master switch.
    This will help extend the life of your hot air blower and this is similar to projectors performing a cool down cycle (fan runs for a few minutes until cool) when turned off by its Standby function.
    • 31014
    Re: Extending the life of your hot air blower
    most blowers dont have a master switch anyway!
    • japlytic
      • Oct 2005
      • 2086
      The master switch I am refering to is the mains switch.
      • rs232killer
        • Feb 2015
        • 89
        • Portugal
        my 5 cents and by experience (can be wrong,is so pleaserefrase to- by fetish)
        - avoid bumps when hot because resistances can break easily when hot
        - avoid using station on max temperature, most stations never reach top temperature or hardly keep it so will continually pump current to resistances, this apply to solder irons too
        -solder irons i prefer to use the brass wire (if this is the english technical term) because cleans better and gives longer life to tips
          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 05:30 AM
        • stormanimal83
          Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
          by stormanimal83
          i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
          08-04-2024, 01:47 AM
        • Natob82
          Micro Momentary Push Switch?
          by Natob82
          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
          12-21-2022, 05:22 AM
        • grimacelord
          NEC TurboExpress On/Off Power Switch Replacement Help
          by grimacelord
          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
          11-09-2023, 09:49 AM
        • SluggerB
          Help making a switch work the opposite way with a relay
          by SluggerB
          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
          02-07-2025, 07:57 PM
