Can anyone suggest a rework station <= $200
  • zdsh07p9
    • Nov 2013
    • 155
    I want to start doing more SMD projects and would like to buy a rework station that is $200 or under. If you could, please let me know what you like and dislike about your suggestion (if you own one). Thanks a bunch,
    Z
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Can anyone suggest a rework station &lt;= $200
    Here's mine. A very useful tool, I use it as much for smd work as i do removing phone and tablet screens. It's a copy of an Ayoue i believe. I am happy with it.
    In hindsight i'd have saved some money and just bought a similar machine but without the soldering iron and thus saved some money.
    • zdsh07p9
      • Nov 2013
      • 155
      Ah Thanks Diif, I am thinking of going Aoyue. Just want something that is going to actually work for a while.
        • 31199
        http://www.dx.com/p/gongjue-8018lcd-...rk-blue-277080
        • gmit77
          • Oct 2014
          • 5
          • Italy
          this works really good Steinel HG2310LCD
          I think this is the link for your country
          http://www.steinel.net/Professional-Heat-Guns/HG2310LCD
          running, biking, oscilloscoping
          • shahnld
            wds-580 rework station issue
            by shahnld
            Good day.
            i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
            Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
            kind regards...
            03-28-2024, 01:14 PM
          • minimania
            Need Schematic for jbc am6800 rework station
            by minimania
            hi all im looking for a Schematic for jbc am6800 rework station
            mine has stopped working fully
            it started with turning off when switched on then after a few off and ons it worked sort of for awhile
            now it wont turn on at all...
            01-28-2025, 03:44 PM
          • shahnld
            Seamark ZM-R6200 Rework station
            by shahnld
            Good day Experts.
            I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
            Kind regards
            01-24-2024, 10:55 AM
          • petemanuk
            Help with IR6500 rework station
            by petemanuk
            I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
            1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
            2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
            10-14-2022, 12:31 AM
          • Peter_1402
            Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
            by Peter_1402
            Hi Everyone,
            I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
            1. Soldering iron works great
            2. There is a burnt mark on the hot air gun handle.
            I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
            Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
            Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
            Reed switch tested ok with a magnet.
            From the above test, I can conclude...
            07-12-2025, 11:50 AM
