New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
I want to start doing more SMD projects and would like to buy a rework station that is $200 or under. If you could, please let me know what you like and dislike about your suggestion (if you own one). Thanks a bunch,
Re: Can anyone suggest a rework station <= $200
Here's mine. A very useful tool, I use it as much for smd work as i do removing phone and tablet screens. It's a copy of an Ayoue i believe. I am happy with it.
In hindsight i'd have saved some money and just bought a similar machine but without the soldering iron and thus saved some money.
Good day.
i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
hi all im looking for a Schematic for jbc am6800 rework station
mine has stopped working fully
it started with turning off when switched on then after a few off and ons it worked sort of for awhile
now it wont turn on at all...
I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
Hi Everyone,
I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
1. Soldering iron works great
2. There is a burnt mark on the hot air gun handle.
I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
Reed switch tested ok with a magnet.
From the above test, I can conclude...
