Re: Suggestions which FLASH programmer to buy...
unfortunately RT809F (with PEB1) doesn't support K9GAG08U0E-SCB0
I recently purchased RT809F+PEB1 just to program this particular chip but so far no luck reading or adding this chip.
seems like RT809H supports it , also XGecu T48/T56.
just a quick question:
the samsung nand chip can be written as:
k9gag08u0e with rt809f + peb1 expansion board?
unfortunately, I couldn't find a clear reference to it, only the rt809H.
Does anyone have experience?
Many thanksLeave a comment:
http://www.ebay.com/itm/TNM-2000-USB...-/321207236799
There is a 5000 model also.Leave a comment:
Whichever one has the best software or support. All the fancy hardware in the world won't do anything if they decide to release only some shitty software that only works in Windows 95 or something.Leave a comment:
you mean how to read the chip?
well use linux and use the DD command to copy the whole device as sectors to a file.
or there are windows programs to do it, but i cant remember the name.
keep in mind, you probably cant make sense of the dump, it's only good for cloning.
most serial flash uses some type of filesystem.
if you dont know the detail you cant mount it and mess with the content.
also, writing to flash with errors may be an issue because the error mapping may clash with the dump.
these issues arent related to xd-hacks, but effect *all* nandflash programmers.Leave a comment:
yes yes! but how you read the dam HEX file!
my head hurts! pfffffLeave a comment:
if you just want to do serial nandflash,
you can use a modified xd-picturecard reader.
those are just nandflashLeave a comment:
i'm doing a lot of 32Mbit chips, and i'm glad i'm using a 48XP to do them!Leave a comment:
I guess it would be slower than a USB one. But I haven't seen anything take 1 hour though... but I haven't tried anything over 16Mbit IIRC, which took a few minutes. Most chips I do are very small and are under a minute.
I don't even know if it supports anything really huge.. I doubt it.Leave a comment:
but it's like, 1hour per chip or something from what i remember!!!Leave a comment:
It works - when you load the right program version.Leave a comment:
Stilling running a parallel-port based Willem here... I don't use it much!Leave a comment:
i did not, most of the time i use them to flash notebook bios. But i also use on MAXIM 29LV008CBTC-70G FLASH MEMORY chip and its doing great.Leave a comment:
rtstorm, did you try to erase, program and test large TSOP48 4GB NAND flash chips?Leave a comment:
i have the TL866 with many adapters and it is working fine, the released the 6.1 version now. It is simple tu useLeave a comment:
Chriso, thank you for the link. Well, is a 39 pages thread, so I suppose answer to my question won't be so easy ;-) Actually, I'm not quite optimistic about this programmer is capable of programing 4GB NAND flash chips...
SLeave a comment:
Have a look at the EEVblog - there's a huge thread there about it
I bought mine from Amazon.Leave a comment:
by what_1282105Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
Channel: BIOS Requests ONLY!
by ugamazingI'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
by ekozeko333Hi all,
I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
🔥 The Problem Started After Suspected ESD/PD Fault
I experienced a power issue or ESD event through a USB-C charger
After that, the NX20P5090 power switch was visibly burned and was replaced
Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
🧠 What I’ve Done So Far
Flashed...-
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
Yesterday, 05:47 PM -
- Loading...
