Multiple oscilloscope channels
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8672
    Well of course the more the merrier but have this one assumption that you're not going to be viewing digital signals (use a LA or mixed signal for this),
    How many channels do you think is minimum to be truly useful?
    I have a 2-channel scope and a lot of the time I just use one channel and it's sufficient. Those of you who have 4-channel, how often do you use three or more channels? What do you use it for?
    And even 2-channels, do people use both frequently?
    I guess for DSOs that can measure lag, this is sometimes useful but a lot of the time even lag isn't a very useful number in debugging...
    Note: Query is for multiple Y axis scopes, not external trigger/sweep/Z scopes...
  • Dans2530
    • Aug 2014
    • 15
    Re: Multiple oscilloscope channels
    I'm not a scope expert but I would assume that you could do math operations using the scope on more than one signal as a sort of differential analysis?
    If someone that has a heap of scope experience could lend their opinion on this, it would be appreciated, I'm here to learn as well.
    • Uniballer
      • Jul 2013
      • 334
      I can generally get by with two, but it takes three just to see input, clock, and output for one signal.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8672
        But with clocks, that mostly implies having digital, that which a logic analyzer might be the better solution. But for analog signals?
        There are definitely advantages to multiple inputs even on analog, but what kind of math do you do on analog? Especially with three or more channels, it gets kind of confusing. Not to mention that I think most scopes that have multiple channels, the sampling bandwidth of each channel goes down as more channels are used.
        I just wonder whether I should forgo a 4-channel unit and look more toward a high sample rate/bandwidth 2-channel unit.
          At MINIMUM two channels.
          Two channels lets you sync events. With memory or a camera, you can do virtually anything with just two channels (it'll just take you a lot longer!)
          Two + ext trigger is a nice upgrade, frees a channel for a trigger.*
          Four channels IMHO... once you go there, you never go back.
          Rigol's new DS1054Z scope offers 4 channels at 50MHz/1GSas for under $400. It can be upgraded to 70 or 100MHz bandwidth and supports serial decode, serial trigger, advanced triggering, and up to 24Mpts memory at full sample speed. (Yes, 24 megapoints... That's more than most $2000 Agilent & Tek scopes!!)
          Crazy value for the money...
          Recently, used four channels on a multiple motor project. I could look at data going into the motor drivers (clock+DATA) plus POS and NEG motor terminals. Then use MATH to extract motor voltage from that and serial decode on I2C lines. And the DS1074Z (upgraded to 100MHz+options) coped with it like champ.
          • gmit77
            • Oct 2014
            • 5
            • Italy
            ciao, first I would look at the sample rate Vs bandwith. you want to have min 3 time the sample rate of the bandwith. two channels is often enough, it is growing the need for analog + digital and you can find good quality 2 (a) + 16 (d)
            some models offer multiple math actions, but this dipend more on your budget.
            advanced trigger and decoding is also interesting, use them more as tab instead as display.
            the new trend of big name is the 8 channels! maynly for Power and Automotive application.
            we see lot of demand for Pico 4824 which is the 8 channels USB pc scope
            if you like I can add links to application notes.
            ciao
            running, biking, oscilloscoping
            • Tarot Superstars
              How not to Damage an Oscilloscope
              by Tarot Superstars
              Hello.
              I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
              I want to learn how not to damage it, and I found instructions on the internet obscure.
              They talk about ground, earth, floating ground, this, that....
              But they don't actually say anything anything useful so far.
              I want to know:
              Don't connect exactly this to exactly there or it blows up.
              For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
              I want to know what not to connect...
              08-29-2023, 02:27 PM
            • petehall347
              looking for portable oscilloscope
              by petehall347
              i could do with a scope for car work . need a decent screen size and best to have at least 2 channels .
              this one caught my eye and wondered if anyone can recommend it or a better one for around similar price .
              https://www.fnirsi.com/products/1014...S4e5yK-_o5JU8C
              02-20-2025, 05:21 PM
            • r2digital
              Harmon Kardon AVR340 no sound on 4 channels
              by r2digital
              Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
              03-09-2024, 01:33 PM
            • rustinjust
              Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
              by rustinjust
              My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
              The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
              It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
              I have to turn the tv off and then on again with...
              09-28-2023, 12:23 PM
            • pavithra_uk
              CRT Oscilloscope repair
              by pavithra_uk
              I received two GW Insteak GOS-622G 20Mhz Analog CRT oscilloscopes to repair. both have shorted transistors and fried resistors in Y plate drive circuit.
              since both have same issue, I want to find if this common issue with this scope or any other cause. here I attached schematic of Y output circuit.
              C2570 Transistor. this is Gigahertz range low power transistor (VCBO-25V, VCEO-12V, 50mA) for use in VHF/UHF range. but, that transistor here in the circuit of 160V supply. both scopes have both this transistor fried.
              Transistors with heatsink - 2SB648A,...
              08-26-2022, 07:02 AM
