Testing ESR with an Oscilloscope
  • Stephen Powell
    • Jul 2007
    An oscilloscope can be used to check ESR by using a very simple test circuit. All you need is a square wave generator (a 555 timer will do!) and a few resistors. The details are at my web page at
    http://octopus.freeyellow.com/99.html
    There are some links to other related pages at
    http://octopus.freeyellow.com/esr.html
    Usually the kind of capacitors that have ESR problems are used to reduce voltage ripple in power supply lines. The result of increasing ESR is an increase AC ripple on the DC supply line and a scope can test for this, provided you can find a place for the test probes.
  • lmcancu
    LED Strip test points and testing?
    by lmcancu
    Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
    Thanks in advance...
    03-20-2023, 07:52 AM
  • praveenramavath
    Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
    by praveenramavath
    Hello All,
    I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
    https://www.hifivision.com/threads/m...-screen.98243/
    Troubleshooting Summary: Majority Internet Radio - Flash Chip
    04-26-2025, 09:08 AM
  • bauto601
    KDM 480W PSU upgrade succes! (opinions?)
    by bauto601
    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
    A "nice" YoungYear unit? - Badcaps
    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
    12-26-2023, 03:05 PM
  • R7027
    How to probe TP7002 for AP_PS_HOLD on SM-G930F?
    by R7027
    In the service manual for Galaxy S7 (SM-G930F), step number four in the flow chart for troubleshooting power-on issue is to check the voltage level of a "signal".
    I had a very hard time locating this. I didn't understand what it means to check for voltage of something by its signal name, and it's location was not described in the service manual (not that I could see in my four chapter excerpt of the complete manual). Then I learned that this signal name needs to be translated into a test point (TP) ID on the board. This is unlikely to be referenced in a service...
    01-02-2023, 06:25 AM
  • chth96
    How Can I test PWM DM0365R?
    by chth96
    Hello
    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
    06-18-2025, 04:14 PM
