The Cen-Tech LE830b 7-function DMM from Harbor Freight Tools
  • Jidis
    • Nov 2013
    • 64
    Re: The Cen-Tech LE830b 7-function DMM from Harbor Freight Tools
    Originally posted by lti
    wiggling the range switch would cause the reading to change
    I coincidentally started getting the same thing not long ago on my Vichy LCR meter. It would give me crazy readings that I knew weren't anywhere near the right values. It took me a while to figure out it was from the switch. Seems like mine somehow doesn't quite land on the notches and I can usually flip it a couple spaces and back to fix it. If it gets worse I'll go in and clean it like you did.
    I never liked those stupid rotary dials they all use, but I guess it's the most cost effective way of handling that many lines. At least Cen-Tech used a separate power switch to save a bit of wear on the dial.
    Take Care
      master hoarder
      • May 2008
      • 12175
      After I last posted in this thread, it became more difficult to make low resistance readings... so I cleaned the range switch and power switch with alcohol... After cleaning, the low battery warning doesn't appear and all measurement ranges work. I get 0.3 ohms when shorting the leads, even with the original test leads.
      Nice!
      I might try that as well. I also have to wiggle the range dial back and forth on all of my 830 meters to get a good reading. I think the worst one I have is my oldest DT-830D (not from HFT), which doesn't have an ON/OFF button, but rather you have to rotate the range dial to the OFF position every time. Being nearly 15 years old and used quite a bit, I bet those contacts are either dirty or plain worn now (or both?).
      Yes, I like that feature as well. Also, if you use a certain setting a lot, you can leave the dial on that and not have to turn it every time. For me, it is the 10A current range - every time I supply power to a LV electronic circuit I built, I always monitor the current.
      • Jidis
        • Nov 2013
        • 64
        Yeah, that's why I'm not into the ones without a separate switch. Seems especially risky with stuff (like the Cen-Tech) that you already know isn't of the finest build quality to begin with.
        I think for this particular meter, mine would probably be the 20V DC range. Oddly enough, I actually use it to set voltages on my benchtop power supply which has it's own meters (the analog style).
        BTW, it would be cool if the crappy contacts are the main reason for the Cen-Techs being off in that low resistance range. Seems to be one of the main gripes you hear regarding its accuracy. I've got one of those small calibrated reference boards, and I think my two Cen-Techs were also only noticeably off in that one area.
        Take Care
          master hoarder
          • May 2008
          • 12175
          Guess what folks?
          My old DT-830D was starting to act up quite a bit on the resistance and continuity settings. So today I tried what lti did in post #20.
          And you know what? IT WORKS ABSOLUTELY 100%!
          lti, you are a genius, man
          Now my old DT-830D measures all the way down to 0.2 Ohms (on the lowest resistance setting) when I short its leads. And even if I wiggle the dial, it won't go above 0.4 Ohms. That is a HUGE improvement. Before, I had to wiggle it to get it down to 1-2 Ohms. Now, it is like brand new... or maybe even better .
          I guess my HF meters will be next in line for that.
          I think that really IS the reason why they measure resistance off. I mean, my old DT-830D was worse than bad - I'm talking about being off by as much as 100 Ohms on the 200 Ohm scale if the dial wasn't set "right". And now, it is perfect.
          Unbelievable how much difference a piece of paper towel, some IPA, and 5 minutes of time can make.
          • corrize
            Small and robust multimeter probes
            by corrize
            Hello, I search a new probes for measuring pin of qfn and other very small stuffs. I bought the AE basics ones, but they are no longer sharp. Metal is bad. Do you have a stonger ones ?
            05-13-2023, 02:36 PM
          • trex66
            Craftsman 82345 Multimeter broke!
            by trex66
            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
            03-04-2025, 04:26 PM
          • Sofian75
            Things not to do with a multimeter?
            by Sofian75
            I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
            I fixed some of them and some I ve made things worse by blowing components.
            Every time while taking measurements with my multimeter.
            Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
            So my question is are there things I should not do with my multimeter?
            Or measurements I should do only with the charger and battery unplugged?...
            06-27-2024, 05:13 AM
          • max_smart
            T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
            by max_smart
            First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
            Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
            06-01-2024, 03:27 PM
          • dj8452000
            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
            by dj8452000
            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
            02-18-2025, 08:28 AM
