Can the CH341A chip be programmed?
  • Sparklingx
    replied
    Originally posted by CuriousDave
    I am just wondering how much the programmer cost where you live. Isn't it cheaper to buy the programmer instead of trying to fix it? I just bought a new one from Amazon to find out if it reads the T2 ROM and it cost about $12 with two TSOP adapters and cables.
    I got mine for a discount, 4.5$ including test clip & 2 sop16/8 - dip8 board
    replied
    it's a 3.3v device - isnt the T2 rom 1.8v?
  • CuriousDave
    replied
  • rogfanther
    replied
    Can you measure the voltages in U1 ? Also, please re-check the soldering of the usb connector.
  • hadyshahat
    replied
    The problem is not in the definition, the problem is in the IC
  • lotas
    replied
    Update your driver. https://www.wch-ic.com/downloads/CH341SER_EXE.html
    https://www.wch-ic.com/downloads/CH341PAR_ZIP.html
  • hadyshahat
    replied
    The measurements are correct for a working LED but my computer does not recognize it.
    replied
    do you see the power led light up?
    if not check the fuse-resistor,
    if you do then look at the 12MHz crystal and it's 2 caps
    replied
    Originally posted by hadyshahat
    The computer does not read the original programmer.
    The LED has green corrosion on one pad,and on the other its blackened. C1 looks like its metal ends are missing. The USB socket pins might have some corrosion on them. C2 is broken/missing. The soldering on the F1 fuse doesn`t look too good. Besides all that the 16 pin socket is very dirty inside.
    Did you check the fuse,voltage regulator and xtal.​
  • harp
    replied
    If power led turn on when connecting to working USB, then check if you have 3.3v present.
    If LED stay off while inserted into usb, you have
    - not vorking usb or
    - not working led circuit or
    - blown fuse or
    - short on pcb
    Check all that and report back with info.
  • hadyshahat
    replied
    Originally posted by Sparklingx
    you can try one thing connect a capacitor from GND to VDD then try. your's and mine are same board and chip(CH341B not A)
  • harp
    replied
    The reason for the chip damage is that the IC was installed in the opposite direction, so the CH341A chip reached a high temperature and burned out.
    In that case, check also fuse and vreg. The soldering job... I will redoing that, it not look promising. At least, check that you dont have mechanicaly loosing legs of IC (say... crucial pin#14 X0 looks like bumped by cold joint) by slightly pushing every pin by its side - it must staj firm, no any movement... and check to pin by pin do not touch by side eg pin#1 and #2... use flux in the proces.
    Put back C2 also, it is 100nF on 3.3v rail.
  • Sparklingx
    replied
    These are pictures of the programmer.
  • hadyshahat
    replied
    Originally posted by stj
    post a picture of the board.
  • Sparklingx
    replied
    Originally posted by harp
    You have to inspect every track for connections and voltages, according to schematic.
    What is the reason to chip die?
    hi what is the job of "pin 25" ? In my programmer pin 25 is not soldered but mine works fine(read,erase,write,verify)
    replied
  • hadyshahat
    replied
  • hadyshahat
    replied
    Originally posted by SMDFlea
    What chip are you trying to read. Which CH341A do you have, post a picture, and what software version are you using.
    I bought a new chip for the programmer because the old chip was damaged and the new one when I installed it did not read on the computer and it does not sense it at all and the program I am using is version 2.2.10 it is the best program and I have been working on it for a long time because it is a very good program but the programmer does not read on the computer
  • harp
    replied
    replied
    Is it possible to program the CH341A chip, because I bought a replacement part and replaced the damaged one, but the programmer does not read?
    Please help​
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
    How to add chip support to NeoProgrammer software for the CH341A Programmer
    by SMDFlea
    Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
    and once you do find them there`s a few crucial steps missing.
    Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
    Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
    After adding the chip save the xml file and copy it to the root directory of the...
    05-26-2024, 07:15 AM
  • hotcrossedbuns999
    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
    by hotcrossedbuns999
    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
    3. I could only locate two chips that look like bios chips. Could someone verify this
    01-03-2025, 12:32 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
    by SMDFlea
    Bad...
    09-02-2021, 04:40 PM
