Can the CH341A chip be programmed?
    replied
    ch341a does not contain any data - something else maybe wrong - check it's getting power
  • hadyshahat
    started a topic Can the CH341A chip be programmed?
    Is it possible to program the CH341A chip, because I bought a replacement part and replaced the damaged one, but the programmer does not read?
    Please help​
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
    How to add chip support to NeoProgrammer software for the CH341A Programmer
    by SMDFlea
    Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
    and once you do find them there`s a few crucial steps missing.
    Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
    Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
    After adding the chip save the xml file and copy it to the root directory of the...
    05-26-2024, 07:15 AM
  • hotcrossedbuns999
    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
    by hotcrossedbuns999
    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
    3. I could only locate two chips that look like bios chips. Could someone verify this
    01-03-2025, 12:32 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
    by SMDFlea
    Bad...
    09-02-2021, 04:40 PM
