How to locate high value short component
  • harp
    • Jun 2022
    • 616
    • Planet Earth
    It is not so important rather then discusion... for learning.
    I have small box where put bad components in it, shorted diode, caps, burned resistor etc. I was trying to do some yt video about tracing shorts, so, I use one of these bad smd caps from box... it has few ohms, idealy for presentation... I put him on a known good pcb board, on 3.3v rail, parallel with other caps... but, after it cools down, the rail has 85 ohms... when I apply power, it took only 35mA and no voltage drop... so 0.1W...
    Any idea, your experiance how to find 85R bad caps technique?
    • 31165
    only way i can think of is a low-ohms meter like a shorty to compare the resistance of the 3.3v rail at various points till you close in on the lowest reading
    • harp
      • Jun 2022
      • 616
      • Planet Earth
      I have not low-ohms meter to see if is capable to find 85R in parallel... maybe, but it must be very precise and wide range...
      I try to inject volteges and see if any difference I can spot, on faulty cap or other. My dmm have 4000 count, so on 3V it show milivolts. Not a tiny difference for sure between all caps in rail while measurement cant see.
      I hoping that the current path can be detected somehow, without modifiing pcb, so I inject pulsed 3V about 4kHz 75% and try searching some magnetic field with loop... but nothing again. Maybe different probe? Hall sensor?
      I have not RF knowledge so I dont know how resistor will act in high frequency, with another resonant component or so, and can this be used to determine location or area anyway...
      BTW, heating and cooling technique in this case I tend to avoid, becouse of unstable condition, eg, cap after threatman can be 100k... and potentialy catastrofic fail later.
        • 31165
        4000 count isnt great - what chip is in the meter? some are 6000 or even 10,000 count chips but they cripple lower models to justify the price differences.
        i had an idea.
        voltage injection wont work - on it's own.
        voltage injection with current limiting to a few mA may cause a noticable voltdrop difference between different places.
        • megaraider
          • Jul 2015
          • 307
          • Portugal
          Well finding a short capacitor in a power rail is never an easy task unless a visual inspection reveals a cracked / smoked / burned one.
          Less yet when you're trying to find it by measuring (the shorty project might be the most helpful here).
          On the other end you have some well proved heuristic guess techniques, because a low resistance capacitor will heat way faster.
          Thus:
          1. 99% IPA spray over the board, power it up, the defective cap will make IPA evaporate faster;
          2. Cooling spray, ...
          3. Thermal camera
          4. (...)
          • petehall347
            • Jan 2015
            • 4434
            i use my dmm on 200 ohms scale and see how long the beep lasts and also watch the reading then swap the probes .
            • harp
              • Jun 2022
              • 616
              • Planet Earth
              Stj, sorry for gap... I have not forget to feedback soon.
              • harp
                • Jun 2022
                • 616
                • Planet Earth
                Stj... it is Vici VC97 dmm what I have.
                Your idea dont work. I have 3.260v supply and serial connected 300 ohm - that is feed to "shorted" board and give 1.666v on very input point, on various good capacitor in rail and on faulty one. Exactly same voltage 1.666v on all point.
                Also, I inject 3.2v into rail, and monitor temperature of components with narrow low-mass ntc. Before connecting to power, all on pcb are measured 31.1 deg.C, and after connecting power, and wait a while, few minutes, there is no any difference between shorted cap or a goods one, all have same temperature 31.1, only main uC go some higher 31.9 deg.C and its surrounding fade off...
                I dont have thermal camera, but I also doubth that the faulty capacitor (about 85 ohm) will be seen on it. Consumption on whole board is about 0.1W and most of the power go to main uC.
                Regardless IPA...
                There is no way to fine cotrol thickness of applayed ipa, and continuous shape, due to capilary effect and surface tension. On wery small power consumption, there is no any visual sign that for sure indicate suspicion for some location. While apply ipa in various thicknes and coverage, ipa evaporate unevenly where cooling surface area and interference with observation.
                When you reach some power point who can be seen, ipa frst act like some small tension moves (see like light reflection moving from fluid surface) regardles to on/off power, but I am very far from that point.
                The next level is to slightly faster evaporate then surrounding, but it takes even more power.
                On yt is common to see detection with ipa where is disipated 1w or so on small component...
                So for you who have that kind of equipment like liquid air, thermal camera and so on, just solder on scrap board 82 ohm resistor (must be smd for better cooling) on 3.3v rail and try detect it when is all cooled down. I am interesting for results and technique that work.
                Peteh... I dont understand your method, it is not clear... can you explain how to it work?
                • petehall347
                  • Jan 2015
                  • 4434
                  thats a quick way of testing for open or shorted caps on the board . the more uf the longer the beep unless its constant beep of course . i dont use a capacitor meter if i take one out a new one goes in .
                  • DynaxSC
                    Extreme High Current & Low Voltage Short Killer ??
                    by DynaxSC
                    Hi Folks
                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                    After taking off the socket, the shorts dissappear again.
                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                    10-15-2024, 10:13 AM
                  • grimacelord
                    Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                    by grimacelord
                    Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                    After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                    I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                    10-24-2024, 12:31 PM
                  • nagkiller
                    Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                    by nagkiller
                    Hello everyone!
                    This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                    After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                    Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                    The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                    I would like some...
                    05-10-2025, 09:19 AM
                  • joshAU
                    Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                    by joshAU
                    Hi all.
                    This notebook was showing no signs of life.
                    I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                    However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                    If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                    I tried replacing the MOSFET with a new one, but again no voltage on the...
                    05-29-2024, 12:33 AM
                  • techrepairheide
                    Gaming laptop Clevo NH79EP with short on 5VS-rail
                    by techrepairheide
                    first of all I want to apologize for my bad English, but I try to give my best.
                    Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
                    For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
                    10-13-2024, 02:49 PM
