How to IT822E-256 dissolder
  • 220vdc
    • Nov 2022
    • 18
    • Italy
    Hi I'm not able to dissolder this chip...air solder station 380-450° 30 seconds nothing happened...I don't want destroy motherboard. Any tricks? Grazie
    • 31198
    go over the pins with leaded solder to lower the melting point of the original tin solder - that i suspect is pure tin!
    i'v seen this problem many times while lifting flash chips.
    • 220vdc
      • Nov 2022
      • 18
      • Italy
      Thanks you,
      solution was air 500° for 50 seconds.
      • corrize
        Best way to solder LVDS connector for beginner (and qfn) ?
        by corrize
        Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
        I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
        I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
        See the test :
        https://youtu.be/bNAzC-EvqHs?t=1767
        With hot air from bellow the board, that's...
        03-09-2023, 02:57 AM
      • petemanuk
        BGA solder balls not connecting - help pls
        by petemanuk
        So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
        I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
        I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
        11-16-2022, 05:21 AM
      • myth77
        UV solder mask - high temp resistent, recomendation?
        by myth77
        Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
        Is there any solder mask...
        03-28-2022, 04:04 AM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • sircastor
        Solder not reflowing - what am I doing wrong?
        by sircastor
        I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
        For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
        03-03-2024, 02:44 AM
