Best tool to place electrolytic SMD caps on a board
  • tony359
    • Oct 2018
    • 264
    • United Kingdom
    HI all,
    I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
    When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
    The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because I am installing hundreds of them, I'd be keen to have the best tool for the job!
    I think the ideal tool would be short, grab the can of the cap, provide some grip and allow crowded installation where the cap has to be grabbed from an angle.
    Any ideas?
    Cheers!
    Tony
  • diif
    • Feb 2014
    • 6978
    • England
    I'd save time by using the twist off method for removing the old caps.
    A finger or tweezers for holding the new cap in place.
    • harp
      • Jun 2022
      • 644
      • Planet Earth
      Not in dimension/proportion, just idea
      • diif
        • Feb 2014
        • 6978
        • England
        I've also used a spudger with a bit of blu-tac on the end once or twice to hold components.
        • tony359
          • Oct 2018
          • 264
          • United Kingdom
          harp
          Yes, that is what I am thinking of. I never thought of making them out of wood though! I don't think I have the skills. I cannot find anything similar off the shelf. Thank you for taking the time to make the drawing, it's appreciated!
          I could try with some metal tweezers and bend them to a similar shape though. Then add some heat-shrink for friction.
          I can try blue tack but I'm not sure it would offer a "single handed" operations. Again, I've replaced 700 capacitors so far. The plastic tweezers I use are ok, but something like harp mentioned would probably give me a better grip. Even if I save half a second, multiplied for all those caps it would be some serious time saved!
          Pliers are out of the question. I tried on the lager caps which are difficult to de-solder (because on power planes) and I ripped the pad. This is paid work so I don't want to butcher the PCBs. (I wouldn't do that anyways of course!)
          • harp
            • Jun 2022
            • 644
            • Planet Earth
            If is easyer to you to work with metall... some thoughts
            • diif
              • Feb 2014
              • 6978
              • England
              If you ripped a pad, your plier twisting technique is wrong. Saving half a second on 100 caps is less than a minute.
              I can stick a cap on a spudger with blu-tac and hold that in my left hand then solder with my right.
              You could also use a tiny drop of UV glue to hold the caps in place.
              • tony359
                • Oct 2018
                • 264
                • United Kingdom
                harp
                You are my new hero Your drawing skills are impressive!
                I think that is what I'll try to do. I'll keep you posted! Thanks!
                  • 31260
                  i dont fit smd electrolytics - they are shit.
                  real men spend the extra and buy smd tantalums
                  • tony359
                    • Oct 2018
                    • 264
                    • United Kingdom
                    Oh well, speak to the manufacturer then
                    I suppose it's good for them with electrolytics. With tants, those units would still be in service
                    • madscientist750
                      Replacing electrolytic caps by solid caps on old motherboards
                      by madscientist750
                      I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                      I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                      I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                      10-19-2025, 06:10 AM
                    • Perry Babin
                      How do organic polymer caps compare to liquid electrolytic for reliability
                      by Perry Babin
                      I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                      If not organic polymer, what would be the caps that could take the most abuse?
                      08-18-2025, 04:04 PM
                    • rex98
                      HP DMI Tool
                      by rex98
                      HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                      DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                      The DMI Tool given here are for personal use only.
                      DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                      You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                      from it, and that you please credit the author...
                      07-02-2025, 05:51 AM
                      by momaka
                      03-12-2025, 03:42 PM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
